Linear Circuit - current through Load Resistor
The discussion revolves around calculating the load current through a resistor in a linear circuit when different load resistances are applied. Participants explore the relationship between load current and load resistance, addressing a homework problem involving a 2-kΩ, 10-kΩ, and 20-kΩ load.
  • Homework-related
  • One participant proposes using the slope between the two given currents and resistors to find the current for a 20-kΩ load but finds this method incorrect.
  • Another participant explains that the relationship between load current and load resistance is non-linear and suggests using Thevenin's theorem to derive the correct values for the circuit parameters.
  • A participant expresses frustration at consistently obtaining a different current value than expected and seeks assistance in identifying errors in their calculations.
  • Another participant requests to see the calculations to help identify potential mistakes.
  • One participant shares their calculations, which lead to unexpected negative values for Thevenin voltage and resistance, raising questions about the correctness of their approach.
  • Another participant points out potential errors in the use of current values in the equations and clarifies the notation used in the function for load current.
  • A participant acknowledges their misunderstanding of the notation and expresses gratitude for the assistance received.
Participants express differing views on the correct approach to solving the problem, with some agreeing on the need for Thevenin's theorem while others struggle with the calculations. The discussion remains unresolved regarding the correct current for the 20-kΩ load, as participants have not reached a consensus on the calculations.
There are unresolved issues regarding the assumptions made in the calculations, particularly concerning the use of current values and notation. The dependence on specific definitions and the interpretation of function notation also contribute to the confusion.
Students and individuals interested in circuit analysis, particularly those studying Thevenin's theorem and the relationship between load resistance and current in linear circuits.
ponomous
When a 2-kΩ load is connected to the terminals A–B of the network in the figure, the current through the load is IL = 10 mA. If a 10-kΩ load is connected to the terminals, IL = 6 mA. Find IL if a 20-kΩ load is connected to the terminals.
2. The attempt at a solution
I thought that I could use the slope between the two given currents and resistors ie (2k-10k)/(10 mA - 6 mA) and then substitute in the 20k resistor and the unknown current into the formula. However this doesn't give the correct answer of 4 mA (given in the book).
Could someone point me in the right direction?
Welcome to PF!
The reason why your method didn't work is because the variation of load current with load resistance is NON-linear. The load current varies inversely with the load resistance, and the function I(R) ~ 1/R is decidedly non-linear.
Assuming that your network (which is not shown) consists of nothing more than an ideal voltage source with a series resistance (or, in other words, reducing it to its Thevenin equivalent), then the open circuit voltage between terminals A and B is Vth. Furthermore, if the series resistance is Rth, then when you place a load resistor RL across the output terminals, the current across the load will be given by:
IL(RL) = Vth/(RL + Rth)​
This is the function that determines how the load current varies with load resistance. Now, you have two unknowns: Vth and Rth. BUT, you also have two equations, since you know IL(2 kΩ) and IL(10 kΩ). Therefore, you can solve for these two unknowns, at which point you'll know everything there is to know about the circuit. From then on, it's just a matter of plugging RL = 20 kΩ into the function. I did it and got the right answer.
Hey cepheid,
I understand what you are saying, and it makes sense, but i have run through this now 8 times and I am always getting 2 mA instead of 4. I can't find anything in my work that is wrong, any ideas?
Thanks
Yeah, show us your work. Post your calculations and the results you got for Vth and Rth. Maybe I can spot where you went wrong...
So when i run through the two formulas i end up with
20(2000) + 20 Rth = Vth
60(10,000) + 60Rth = Vth
Solve and get -14,000 = Rth
This gives me a Vth of -240,000
When i substitute i get IL(20,000) = -240,000/ (20,000 - 14,000)
Which gives 2 mA
Which gives 2 mA
What are the numbers in red? Are they supposed to be currents? If so, what units are they in? The current in the first equation is supposed to be 10 mA, so that seems completely wrong. The current in the second equation is supposed to be 6 mA, so I cannot see how that becomes 60, unless if you are expressing things in units of 10-4 A :wink:
Also, here's a useful tip: you can just keep everything in the units in which they are given. This is possible because:
(1 V) / (1 kΩ) = 1 mA
(1 mA)(1 kΩ) = 1 V
Which gives 2 mA
How? :confused:
What I mean is, even with the wrong numbers, I don't see how you get 2 mA.
Ohhh no! Wait, you realize that in my expression below
that the parentheses on the left hand side represent function notation and not multiplication, right? So, the left hand side should be read as IL OF RL.
I'm sorry if I misled you. :frown: I just thought it would be obvious from the context, since the current, I, must have dimensions of V/R. Plus, I referred to it as a function several times.
EDIT: This blunder also explains why your numbers (that I quoted in red) are weird. They are IL*RL when in fact they should be just IL. Arrgggh...
OHHHHH oops... That is my fault for using notation that is nearly identical to the function notation.
Thanks, I have the right answer now.
I know on some forums they have a thank button or something, is there something like that here? You have been most helpful.
Hey, there's no "thank you" button, but I'm glad to have been of help, and you're welcome. :smile:
  • · Replies 17 ·
  • · Replies 37 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 34 ·
9K
  • · Replies 42 ·
