Linear Collisions; Conservation Law
The discussion focuses on a collision experiment involving two masses, A (100 g) and B (200 g), on a horizontal air track with springs. The speed of mass A as it leaves spring 1 is calculated to be 0.71 m/s. After colliding with mass B, the velocity of mass B is determined to be 0.25 m/s to the right. The maximum compression of spring 2 during the collision is found to be 2.5 cm. The conservation of energy and momentum principles are applied to solve the problems, highlighting the importance of accurate unit conversions.
  • Understanding of conservation of energy (Ep = Ek)
  • Knowledge of conservation of momentum (p = mv)
  • Familiarity with spring constant calculations (k = 20 N/m)
  • Ability to perform unit conversions (e.g., grams to kilograms, centimeters to meters)
  • Study the principles of conservation of momentum in elastic collisions
  • Learn about energy conservation in mechanical systems
  • Explore the effects of spring constants on motion dynamics
  • Practice unit conversion techniques in physics problems
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators looking for practical examples of conservation laws in action.
trulyfalse
Hello Physics Forums!
The student sets up a collision experiment with two masses on a horizontal air track, with two springs on each end. The mass of A is 100 g and B is 200 g. Each spring has a constant of 20 N/m. Spring 1 (left side) was initially compressed 5 cm
to start mass A moving.
a. Determine the speed of mass A as it leaves spring 1 [0.71 m/s]
b. If A has a velocity of 20 cm/s to the right after it collides with B, determine the velocity of mass B. [0.25 m/s right]
c. Determine the maximum compression of spring 2 when mass B collides with it. [2.5cm]
Ep = 1/2kx2
p = mv
I solved part a readily using the conservation of energy law (Ep = Ek). When I tried to solve part b using conservation of momentum, however, I obtained an incorrect answer:
Total momentum before = Total momentum after
m1v1+m2v2=m1v3+m2v4
(m1v1+m2v2-m1v3)/m2=v4
[(0.1kg)(0.71m/s)+(0.2kg)(0)-(0.1kg)(0.02m/s)]/(0.2kg)= v4
v4 = 0.35 m/s right
Am I reading the question wrong? Are my formulae incorrect?​
20 cm/s would be 0.20 m/s, not 0.02 m/s
Hahahaha thanks for your help; I'll have to be more diligent with unit conversions next time!
  • · Replies 16 ·
16K
