Linear Equation with Constant Coefficients Problem
The discussion revolves around solving the linear differential equation \(y'' + y = 0\) with various boundary conditions. Participants are exploring the implications of these conditions on the constants in the general solution.
  • The original poster attempts to solve for constants \(C_1\) and \(C_2\) based on the given boundary conditions, noting difficulties particularly with parts 2-4. Some participants question the implications of the boundary conditions on the constants, while others suggest that certain conditions allow for multiple solutions.
Participants are actively discussing the relationships between the constants and the boundary conditions. Some have offered insights into the nature of the solutions, indicating that certain conditions do not uniquely determine the constants. There is recognition of differing interpretations of the constants used in the general solution.
There is a noted ambiguity in the constants \(C_1\) and \(C_2\) as different participants use different definitions, which may affect their conclusions. The boundary conditions provided do not lead to unique solutions in some cases, raising questions about the nature of the problem.
JM00404
Find all solutions \phi of y''+y=0 satisfying:
1) \phi(0)=1, \phi(\pi/2)=2
2) \phi(0)=0, \phi(\pi)=0
3) \phi(0)=0, \phi'(\pi/2)=0
4) \phi(0)=0, \phi(\pi/2)=0
I cannot seem to solve parts 2-4 in a way that would result in the coefficients being any constant other than zero. Whenever I solve for one of the constants in the equation \phi(0)=0 , I find that C_1=-C_2 ; which isn't alarming yet since the magnitude of either constant is not yet known. When I try to solve the second property in each of the subsequent equations, I find that C_2=0 , for example, which implies that C_1=0 since C_1=-C_2 . Below, I have included a portion of the work that I completed to get to the current situation that I am in. Any assistance offered would be much appreciated. Thank you for your time.
y''+y=0 .
Characteristic Polynomial: p(r)=r^2+1=(r-i)(r+i)
\implies Roots =\pm i .
\therefore \phi(x)=C_1e^ {ix} +C_2e^ {-ix} where C_1 & C_2 are constants.
\phi(0)=C_1e^0+C_2e^0=C_1+C_2=1 \implies C_1=1-C_2 .
\phi(\pi/2)=C_1e^ {\pi i/2} +C_2e^{ -\pi i/2} =(1-C_2)e^ {\pi i/2} +C_2e^ {-\pi i/2} =\cdots=(1-2C_2)i=2 \implies C_2=(\frac 1 2 +i) \implies C_1=(\frac 1 2 -i ).
\therefore \phi(x)=(\frac 1 2 -i)e^ {ix} +(\frac 1 2 +i)e^ {-ix} =\cdots=cos(x)+2sin(x) .
The first condition of 2) gives, as you say, C_1 = -C_2. Using this and the second condition of 2), I get that C_2 can be anything.
Regards,
George
b) y=(c1)sinx
c) y=(c1)sinx
d) y=o
(c1)= any constant
For b and c, I get (c2)=0, so (c1) can be any constant and there is no cosx term
For d, I get both (c1) and (c2) are 0, so the only soln. is y=0
hunchback6116 said:
b) y=(c1)sinx
c) y=(c1)sinx
d) y=o
(c1)= any constant
Careful - I think your C's are different JM00404's C's. This doesn't affect the final answers, but it does affect the values of the C's.
JM00404 has chose C's such that
\phi(x) = C_1 e^{ix} + C_2 e^{-ix}.
I think your C's are such that
\phi(x) = C_1 sinx + C_2 cosx.
Regards,
George
You're right
You're right. The general solution to the equation that I am using is
y(x) = (c1)sinx + (c2)cosx
Lets look @ (2). we have a general solution y=(c1)sinx+(c2)cosx, the first restriction y(0)=0, inplies that c2=0. The second restriction y(Pi)=0 does nothing because for any value of c1, sinx will be zero at Pi. so the solution is a bunch of sine curves with any amplitude. This is a good example of a second order d.e. that has 2 boundary conditions that don't determine a unique solution.
  • · Replies 16 ·
