Linear expansion in a brass plug and steel ring
The discussion revolves around calculating the temperature required for a brass plug to fit into a steel ring, given their initial dimensions and coefficients of linear expansion. The user derived a formula to find the change in temperature (ΔT) based on the linear expansion equations for both materials. However, there is a significant discrepancy between their calculated ΔT of 199.91 K and the assignment's expected answer of -123 C. The conversation highlights the sensitivity of the results to the coefficients of thermal expansion used, suggesting that variations in these values could explain the differences in outcomes. Ultimately, the user is reassured that the discrepancies may stem from the choice of coefficients rather than errors in their calculations.
rhombus
"A round plug made of brass has a diameter of 87.53 mm at 20 C. The plug is to be fitted to a steel ring of inside diameter 87.43 mm. To what common temperature must they be brought in order to fit?"
The linear coefficient of expansion for brass:
\alpha_{b} = 18.7 \cdot 10^{-6} {\frac{\texttt{m}}{\texttt{m} \cdot \texttt{K}}
and steel:
\alpha_{s} = 13 \cdot 10^{-6} {\frac{\texttt{m}}{\texttt{m} \cdot \texttt{K}}
Unknowns: Delta T, L sub F (final L) for both brass and steel.
As we are seeking a diameter, I assumed that the linear expansion equation would be sufficient:
\Delta L = \alpha \cdot \Delta T \cdot L_{0}
I interpret this as a system of linear equations. Delta T is what is sought; L final is also unknown. So we have two equations with two unknowns.
Taking the original linear expansion equation for brass:
L_{b} - L_{f} = \alpha_{b} \cdot \Delta T \cdot L_{b}
I transform it algebraically to make L final the subject:
L_{f} = L_{b} - \alpha_{b} \cdot \Delta T \cdot L_{b}
I do the same for the steel ring and make the two equations equal each other, then I solve for delta T:
\Delta T = \frac{L_{s}-L_{b}}{\alpha_{s} \cdot L_{s} - \alpha_{b} \cdot L_{b}}
I substitute in my values, converting everything to base units (metres from millimetres), then cancelling units, and my result is
\Delta T = 199.91 \texttt{K}
Now, here is the rub - the answer provided in the assignment is -123 C. If I take 20 C and subtract 199, I get -179 C. These answers vary widely, but I cannot see what I have done wrong here. The coefficients were not the ones provided with the assignment, but came out of a table http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html" , which the instructor has used as a source in the past.
What have I done wrong here? If the work looks good, how likely is that this discrepancy would be caused by the linear expansion coefficients used?
PS: The LaTeX renderer in the post previewer is broken, so forgive me if the first example of the linear expansion equation is actually the linear expansion coefficient for steel. That is not what is in my source code.
For steel you have to use the linear coefficient of expansion (αs) where as for brass you have to use the volume coefficient of expansion which is equal to 3*(αb).
Why? We are measuring a diameter in both cases, which is linear.
Anything else to add? How does my work look?
The result is quite sensitive to the values of the coefficients.
Using the values from this table,
http://en.wikipedia.org/wiki/Coefficient_of_thermal_expansion
(i.e. in units of 10^(-6), 19 for brass and 11 for steel) I find 122.6 degrees.
With your values (18.7 and 13), which may not be wrong after all, I've got your original result. It may be just a matter of parameters' values. Consider also the fact that for steel they provide a range of values.
Okay -- that is reassuring. It is probably just a question of which coefficients were used - your result is not far from result given. Thanks!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
