Linear Expansion related to area expansion
The problem involves calculating the minimum tolerance needed for an automobile windshield to prevent breaking due to temperature changes, focusing on the concept of linear expansion and its effect on area expansion.
  • Exploratory, Assumption checking
  • Participants discuss the application of linear expansion coefficients and the conversion of dimensions from cm to mm. There are questions about which dimension to use for calculations and concerns about the magnitude of the results obtained.
The discussion is ongoing, with participants exploring different dimensions and clarifying the use of linear versus area expansion. Some guidance has been offered regarding the choice of dimensions, but no consensus has been reached on the correct approach.
Participants are working with specific temperature changes and coefficients, and there is mention of potential confusion regarding unit conversions and the implications of using different dimensions in calculations.
student 1
An automobile windshild has dimensions of 60 cm by 150 cm. What minimum tolerance in mm is needed to prevent the windshield from breaking if the temperature changes by 200 degrees Farenheight? (The linear expansion coeffecient of galss is 9 x 10[tex]^{}-6[/tex]
(C)-1
area expansion = Ai(Area expansion coefficient)(Change in Temp)
Area expansion coefficient=2(Linear expansion coefficient)
I found my area to be 900,000 mm2 The change in temperature 111 Degrees Celsius. but I'm not getting the right answer when I multiply 2(Linear expansion coefficient)
I'm getting a huge number for my final answer when it should be really small.
You don't need to consider anything beyond linear expansion. They are looking for an answer in mm.
So do I use the 60 mm or the 150 mm? I figured I was trying to over think it.
Good question. Each dimension would have a different answer. If I had to pick, I'd go with the larger dimension. (Note that those measurements are in cm, not mm.)
ok, I'll try them both! Thanks!
