Linear independence of orthogonal and orthonormal sets?
The discussion clarifies the distinction between orthogonal and orthonormal sets in linear algebra, particularly in the context of linear independence. It is established that while every orthonormal set is linearly independent, an orthogonal set may not be due to the potential inclusion of the zero vector, which renders the set dependent. The participants confirm that the textbook's assertion that "every orthogonal set is linearly independent" is incorrect, as the presence of the zero vector contradicts this claim. The Gram-Schmidt process is referenced as a relevant method for generating orthonormal sets.
  • Understanding of linear algebra concepts, specifically vector spaces.
  • Familiarity with the definitions of orthogonal and orthonormal sets.
  • Knowledge of the Gram-Schmidt process for generating orthonormal sets.
  • Basic comprehension of linear independence and dependence in vector sets.
  • Study the Gram-Schmidt process in detail to understand how to create orthonormal sets from orthogonal sets.
  • Research the implications of including the zero vector in vector sets and its effect on linear independence.
  • Explore the properties of vector spaces and bases to solidify understanding of linear independence.
  • Examine additional resources on orthogonal projections and their applications in linear algebra.
Students and educators in mathematics, particularly those studying linear algebra, as well as professionals in fields requiring vector space analysis and orthogonal transformations.
Riemannliness
(Note: this isn't a homework question, I'm reviewing and I think the textbook is wrong.)
I'm working through the Gram-Schmidt process in my textbook, and at the end of every chapter it starts the problem set with a series of true or false questions. One statement is:
-Every orthogonal set is linearly independent. ->My answer:True; Text: False
What's the deal? I thought orthogonality => linear independence. I know if the statement was the other way around then it would be false, since Linear independence =/> orthogonality.
I'd usually write it off as a typo, but the next statement is:
-Every orthonormal set is linearly independent,
which is true in my opinion and the text's, and that makes me think that there's a distinction being pointed out between orthogonal sets and orthonormal sets that I've missed.
Take an orthogonal set of vectors. Add the zero vector to it. What happens?
Oh snap! Good one.
Does the book's definition of orthogonal sets allow the 0 vector to be a member?
Yes, the book takes the stance that the zero vector is orthogonal to every vector.
Need some clarification myself as well:
An orthogonal set is not always linearly independent because you could have a 0 vector in it, which would make the set dependent.
But an orthonormal set must contain vectors that are all orthogonal to each other AND have length of 1, which the 0 vector would not satisfy.
Is that the right logic?
Yes.
Or perhaps you could argue that every orthonormal set contains vectors which are orthogonal with each other and this set is also a basis. Every basis is linearly independent. ==> every orthonormal set is L.I.
  • · Replies 23 ·
