Linear second order non-homogeneous ODE question
5 replies · 4K views
Malby
Determine the general solution to the ODE:
y'' + 2y' = 1 + xe-2x
I know the solution will be of the form y = yh + yp. The homogeneous solution is y = c1 + c2e-2x.
For the particular solution, I have been using the method of undetermined coefficients. c3e-2x won't work as it is not linearly independent of the homogeneous solution. So I guess c3xe-2x.
So y' = c3e-2x(c3 - 2c3x)
And y'' = 4c3e-2x(x - 1)
Following on from this I end up with a particular solution:
yp = ((1 + xe-2x)/(-2e-2x))xe-2x
However wolfram disagrees with me. My question is, is the method of undetermined coefficients ok to use for this ODE? Or should I be using the method with the Wronskian (it's name escapes me at the moment)
Cheers
If you put y(x) = C1(x) + C2(x)*exp(-2x) in the DE, you eventually arrive at a first-order DE in v = dC1/dx + exp(-2x)*dC2/dx.
RGV
RGV
I'm not sure I understand this. Are you able to explain it a little more?
Cheers
I'd have to dig out my book or notes to make sure, but I think your particular solution will also need an e-2x term, so it should be of the form Ae-2x + Bxe-2x. I wouldn't use c's for yh since they're already being used as the constants of integration for yh.
ehild said:
For the method of variation of the parameters, read http://en.wikipedia.org/wiki/Variation_of_parameters.
This problem can be solved for y' as the y term is missing. Denote z=y' and solve the first-order equation z'+2z=1+xe-2x, then integrate z=y' to get y.
ehild
Aha! Of course. It's all so simple once you know what to do... :smile:
Thanks very much!
