The translation operator is [itex]e^{-ipr}[/itex] where p is the momentum operator and r the translation distance. The exponential is defined as a series, but the square of an anti-linear operator is linear, so the translation operator would be neither linear nor anti-linear. I think this might violate the theorem proved by Wigner that says that operators representing symmetry transformations must be either linear and unitary or anti-linear and anti-unitary, but I don't know if he proved that this must be the case, or just that it's possible to define the operators that way. (I think it's the latter actually).
Also note that if we require the function T defined by [itex]T(r)=e^{-ipr}[/itex] to be continuous, then T(r) can't be anti-unitary for any r since it's unitary for r=0.
If you want to know more, check out the appendix of chapter 2 of volume 1 of Weinberg's QFT book.
Thanks Fredrik I had a quick look at Weinberg's version of Wigner's proof but it was a bit a long! I like you argument on continuity but you have already exponentiated a linear operator and then setting it equal to an anti-linear operator will obviously lead to some difficulties. You must begin earlier, considering the infintesimal unitary operator, just for translations for simplicity, and then choosing the P's to be anti-linear rather than linear.
I have just began to look at this and so far it appears we get the constraint that the P's are antihermitian rather than hermitian but I will do some more work on this first.
The crucial point is that anti-linear transformations are discrete, since
they involve a complex conjugation operation. Therefore, such
transformations cannot be of the identity-connected type (i.e., they
cannot be continuous with the identity transformation). This is
similar to how a parity inversion is discrete, and not identity-connected.
Examples of anti-linear transformations are charge conjugation
and time-reversal for a Dirac particle (most RQM textbooks
discuss this).
The waters are muddied further, however, if you consider
transformations that mix the annihilation and creation
operators in QFT (since these implicit mix a field with
its complex-conjugated counterpart). Look up
"Bogoliubov transformations" (used in superconductivity
and elsewhere) for examples of this. A subtle point here
is that these transformations generally take you between
inequivalent Hilbert spaces -- which is why the Wigner
theorem mentioned by Fredrick may (superficially) seem
to be in contradiction with such things.
Its because we WANT operators to be linear, and that its meanigful. From the beginning starting from de Broglie and Schrödinger you describe a particle as a plane wave with [tex]k=p/\hbar, \omega=p/\hbar[/tex], and then you could easilly identify an operator that gives you p. Also Dirac made this wish of lineaity when he formulated the reativistic quantum mechanics.
