Loading of Series vs. Parallel tank circuits
In a series LC circuit, when driven at resonance, the source perceives it as a short circuit plus any resistance from the load. Conversely, in a parallel LC circuit, the source sees the load as an open circuit at resonance. When an inductive load is coupled to the primary inductance in either circuit, it alters the resonant frequency but does not change the fundamental behavior of the circuit. The series circuit continues to act as a short, while the parallel circuit acts as an open circuit. Understanding these dynamics is crucial for effectively utilizing resonant circuits in practical applications.
Jdo300
Hi All,
I have a few questions about resonant circuits when they are loaded. Let’s say that we have a simple series LC circuit and a simple parallel LC circuit driven by a function generator at frequency X. If there is one coil that is inductively coupled to the coil of each circuit and a load of X ohms is placed on each coil, how will the two circuits respond to the load?
From what I understand so far when I series LC circuit is driven at resonance, the source sees it as a dead short (plus whatever resistance there is) and the parallel circuit will not let as much power from the source through at resonance (please correct me if I got something mixed up here). But what happens in the case that the inductive load is placed on each circuit when they are driven at resonance? (assuming that they are not knocked out of resonance by the load).
Thanks,
Jason O
Jdo300 said:
Hi All,
Thanks,
Jason O
In a series resonant circuit, you put the load in series with L and C. At resonance the LC behave as a short and the source sees only the resistive load.
Ina parallel circuit, the load is in parallel with L and C. At resonance the LC behaves as an open circuit and again the source sees only the resistive load.
If you use an inductive load coupled with the primary inductance this will alter the resonant frequency, but the circuit will still behave in the same manner.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 16 ·
