Local Minimum of Potential Function of Spherical Pendulum
The discussion focuses on determining conditions for the potential function (V) of a spherical pendulum to ensure that x = 0 is a local minimum. It emphasizes that V must be positive definite and that the first derivative of V must be negative semi-definite. Participants highlight the importance of constructing the potential function rather than solving it explicitly, as this construction is key to finding the necessary conditions. The second derivative of V is also mentioned as crucial for distinguishing between local maxima and minima. Overall, the main challenge lies in effectively constructing V to meet these criteria.
ovidiupetre
http://img13.imageshack.us/img13/5793/84188411.jpg
Find a condition on b such that x = 0 is a local minimum of the potential function.
To find local minimum, potential function (V) of the system should be written. V must be positive definite and derivative of V must be negative semi definite. I tried to write hundreds of potential functions that provide local minimum constraints but i can't get rid of sin and cos terms from derivative of V so i couldn't find a condition for b to show x = 0 is a local minimum of the potential function.
Which derivative of V must be negative? Also remember that if you write the equation of motion in terms of the force, you can get a nice expression for the potential.
First derivative of course. I couldn't get a nice expression for the potential, my equations are not simplifiable.
The equations of motion are of the form
\ddot{x} = -\frac{\partial V}{\partial x}
From this you can read off V. Now that you have the function V(x), what are the conditions for such a function to have a minimum at x=0 ?
V is a candidate Lyapunov function and it must be positive definite. Moreover, first derivative of V must be negative semi definite in order to x = 0 be local minimum.
The first derivative vanishes at an extremum. The second derivative is used to distinguish between local maxima and minima. You don't need to solve for V explicitly to do this problem, but it's not that hard to do so.
Problem is not about solving V, the problem is "construction of V". If i construct V, i can find a condition to make x = 0 local minimum by looking negative definiteness of the derivative of V.
You're given the first derivative of V. This is enough information to compute the second derivative and find the condition.
First derivative of potential function is not given. Construction of potential function (V) is the aim or the step that is needed to pass. When you construct potential function, the rest is easy.
As I explained in post #2, you can relate the acceleration to the potential. praharmitra gave you the formula up to a factor of the mass of the particle in post #4.
