Location of maximum desctructive intereference
  • Thread starter Thread starter Gravitino22
    Maximum
The discussion focuses on determining the maximum value of y for which fully destructive interference occurs at coordinates (0, y) due to two in-phase radio sources located at (0,0) and (3λ,0). The derived formula for maximum destructive interference is given by the equation dsinθ = (m + 1/2)λ, where d is the source separation. The solution involves constructing a right triangle and calculating the path difference, leading to the conclusion that the maximum y value is 35λ/4. Key corrections to the hypotenuse calculation and the angle consideration were also discussed.
  • Understanding of wave interference principles
  • Familiarity with trigonometric functions and right triangles
  • Knowledge of the Young's double-slit experiment
  • Ability to manipulate algebraic expressions involving square roots
  • Study the derivation of the interference condition dsinθ = (m + 1/2)λ
  • Explore the geometric interpretation of wave interference in two dimensions
  • Learn about path difference calculations in wave mechanics
  • Investigate applications of destructive interference in radio wave technology
Students in physics, particularly those studying wave mechanics, as well as educators and anyone interested in the principles of interference patterns in wave phenomena.
Gravitino22
Two radio sources in the xy plane are in phase and emitting the same wavelength, λ. Their locations are at coordinates (0,0) and (3λ,0). Show that the largest value of y at which fully destructive intereference may occur at coordinates (0, y) is given by
y=35λ/4
Maximum destructive interference : dsinθ=(m+1/2)λ it’s derived from youngs two slit experiment
and ∆L = dsinθ <<< was used to derive the above, d is the source separation.
My train of thought was that since we want the maximum difference in length the angle must be maximum but if the angle was 90 the waves wouldn’t even meet. So I constructed a right triangle from the problem and deduced that the difference in length would be
∆L =y-sqrt(y^2-9λ^2)=3λsinθ
And this is where i got stuck because I am confused on which angle we are looking at.
Any help is greatly appreciated ! thanks
one bump because I still haven't solved this and my test is this week =/. Thanks for the help
That's a reasonable start, but I see a couple of problems...
1. If the right triangle vertices are at (0,0), (3λ,0), and (0,y), then the legs of the right Δ are y and 3λ, and your sqrt expression should represent the hypotenuse (distance from (0,y) to (3λ,0). As you have written it, it does not represent the hypotenuse ... but a simple correction will fix that.
2. I wouldn't worry about the angle. As you probably know, ∆L must be (m+1/2)λ here, where m is 0, ±1, ±2, etc. You can use this fact with the expression you wrote for ∆L.
  • · Replies 26 ·
11K
