Logarithmic scale - interpolation
2 replies · 17K views
FEAnalyst
TL;DR
How can I interpolate between two values on a logarithmic scale plot?
Hi,
knowing the coordinates of two points: ##(x_1,y_1)## and ##(x_2,y_2)## on a linear scale plot, I can use linear interpolation to get ##y## for a point of known ##x## using the formula below: $$y=y_1+(x−x_1) \frac{(y_2−y_1)}{(x_2−x_1)}$$
But how does it look like in the case of logarithmic scale (log-log plot)? How can I get ##y## for known ##x## when I have the coordinates of two other points? So far I haven't found any working formula for that.
Thanks in advance for your help.
Mathematics news on Phys.org
You have to specify what you mean by that ! Example: Plot ##y = x^3## on log-log paper. Suppose you want to interpolate between ##(3,27)## and ##(4,64)## to find ##3.75^3## (is 52.73).
Do you have the coordinates of those points as found on the axis, or in mm on the paper ?
In the first case your $$y-y1=(x−x_1) \frac{(y_2−y_1)}{(x_2−x_1)}$$is still 'valid' in the logarithm world$$
\log{y\over y_1} = \log{x\over x_1}*{\log(y_2/y_1)\over \log(x_2/x_1)}$$as you can easily check with a calculator (or excel ?:) ):
In the second case you do something similar, but you already have the logarithms.
Reply
Just replace all y values by log(y) and all x-values by log(x). That's all. That's exactly what a log-log plot does. Your result is then log(y), but of course you can recover y using y = exp(log(y)).
Reply
