Lognormal distribution question
  • Thread starter Thread starter TooTall65
    Distribution
The discussion centers on understanding the lognormal distribution, specifically regarding the concentration of organic matter along a highway. Participants clarify that the parameters given, sigma = 1.9 and sigma = 0.9, likely refer to the mean (mu) and standard deviation of the logarithm of the concentration variable. The expected value and standard deviation of the lognormal variable must be calculated from these parameters. Confusion arises over the terminology used in the problem, but it is clarified that the expected value pertains to the lognormal random variable. Overall, the thread emphasizes the need to correctly interpret the parameters to solve the problem effectively.
TooTall65
1. The lognormal distribution is identified as a model for concentration of a certain organic matter above a certain stretch of a highway. The parameters of this distribution are sigma = 1.9 and sigma = 0.9. a) Determine the expected value and the standard deviation of such distribution. b) The probability that the concentration of this compound will be at least 10.
2. I have absolutely no clue how to do this. My instructors lectures are next to useless and give pretty much no help.
3. See #2.
If the concentration C has a lognormal distribution, that means that log C has a normal distribution. THe parameters ##\mu## and ##\sigma## are the mean and standard deviation of log C.
So the prob that C>10 is the prob that log C > log 10.
The wikipedia page on lognormal distributions is concise, correct and clear.
That does make sense, and thank you Andrew. I guess I'm confused when it asks for the 'expected value'. Expected value of what? I'm assuming it wants the mean, but it just says 'expected value and standard deviation'. It's confusing.
There should be no confusion---the terms 'expected value' and 'standard deviation (or variance)' apply to the random variable you are discussing, which is the lognormal random variable ##X## in this case. If you read carefully, you will see that the problem described the parameters as "sigma = 1.9 and sigma = 0.9" (but I guess that meant "mu = 1.9"). The problem did NOT use the terms mean (or expected value) and standard deviation to describe these parameters---although they are, in fact, the true mean and standard deviation of the related random variable ##\ln X =Y \sim N(\mu, \sigma^2)##.
To summarize: you are given ##\mu_Y = 1.9## and ##\sigma_Y = 0.9##, and from that you are asked to calculate ##EX = \mu_X## and ##\sigma_X##.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
10K
  • · Replies 30 ·
