Looking for other proof of expanding universe.
The forum discussion centers on the evidence supporting the expanding universe theory, primarily through the observation of Cepheid stars and Type Ia supernovae. Participants emphasize the importance of redshift measurements and the correlation between brightness and distance as per Hubble's Law. They also discuss the cosmological distance ladder and the role of General Relativity in explaining the observed recession of galaxies. The conversation highlights the need for multiple methods of distance measurement to validate the expansion model.
  • Understanding of redshift and its implications in cosmology
  • Familiarity with Type Ia supernovae and their use as standard candles
  • Knowledge of Hubble's Law and the cosmological distance ladder
  • Basic principles of General Relativity and its application in astrophysics
  • Research the methods of measuring redshift in astronomical observations
  • Explore the cosmological distance ladder and its various techniques
  • Study the characteristics and significance of Type Ia supernovae in cosmology
  • Investigate the implications of General Relativity on the expansion of the universe
Astronomers, astrophysicists, students of cosmology, and anyone interested in understanding the evidence and theories surrounding the expansion of the universe.
grounded
The idea of an expanding universe is said to be proven by using the calculated distance of a Cepheid star from us, and the amount of change in the wavelengths of light emitted from the Cepheid star relative to us.
There must be another way to prove the universe is expanding since the above is only proof if you assume that the change in wavelength is caused by the expansion of space. Is anyone aware of another method used to prove the expansion? Has anyone measured the distance of the same Cepheid star several years apart?
Space news on Phys.org
Did you look at the Frequently Asked Cosmology Questions? Is there something in particular that you find difficult?
There is also the redshift of supernovas, quasars, etc. A very good indicator is type 1a supernovas, since they all seem to the same mass at the time of the explosion, their intrinsic brightness is the same. So the brighter an observed 1a SN is, the closer it is too us. This matches with the measured redshift of objects at that distance in accordance with hubbles law. IE we measure the brightness and redshift of a type 1a supernova and BOTH of the measurements fit our expectations and predictions. Correlating two different effects let's us be much more confident that our model is correct.
Here is a link to the cosmological distance ladder. It lists the various methods that we use to determine the distance to objects in space. http://en.wikipedia.org/wiki/Distance_ladder
You can see that there are many different ways of measuring distance. Having more than one way to measure the distance to an object, similar to what I said above, allows us to be confident that our techniques are indeed correct.
The idea of a doppler shift in the wavelength of light is VERY strongly supported by all current scientific theories. We can actively measure redshift in a lab to a very high precision. When we apply that to our observations of the universe, we find that things are moving away from us. Our interpretation of this recession uses General Relativity, the most accurate theory dealing with gravity and very large scale objects like galaxies, clusters, etc. GR explains gravity as emerging from the geometric properties of spacetime. It is the framework of GR that allows us to explain the recession of galaxies away from us as an "expansion of space".
Also, the amount of observations performed in astronomy are staggering. Not only by professionals, but by amateurs as well. Here is a light curve for the star Mira for the last 20,000 days, since 12 Jan 1958.
http://www.aavso.org/tmp3/468617438.png
I pulled this from the AAVSO website in about 30 seconds. http://www.aavso.org/lcg
So yes, we have observed variable stars over the course of several years. If you want to find data on a specific Cepheid variable just use the light curve generator at the link above.
We also have observational evidence the universe was cooler in the past, which is precisely what you would expect in an expanding universe - re: http://arxiv.org/abs/1012.3164, and http://www.das.uchile.cl/das_ingles/new_temp_measurements.php .
Chronos you mean warmer?
I plead dyslexia.
Chronos said:
I plead dyslexia.
There's no pleading in Cosmology!
Cosmology is cruel.
Chronos said:
Cosmology is cruel.
Cruel Cosmology, now offered at a college near you!
OMG, I think I am teaching that course! They will not take me alive.
universe is not expanding only the galaxies are moving away from each other..like the shards after an explosion .space is infinite hard vacuum and these matter and energy is expanding into this nothingness and creating the familiar space that we know of ie space with underlying vacuum energy .UNIVERSE is not expanding !
like in the above video the particles will move away from each other like normally would after an explosion ,space is not expanding ,if the movement of galaxies is because of expansion of space ,then all galaxies will be moving away from each other in same speed
.idk why people invoke this kind of esoteric metric expansion like weird ideas .
This is wrong. You are under the impression that galaxies are moving away from us due to an explosion within space back at the "big bang". This is a classic misconception.
Incorrect. Expansion is the only thing that explains the observed recession velocities. An explosion within space absolutely does not. And that video is not a realistic depiction of a grenade exploding, it is simply a movie someone made just to make it. In a real explosion smaller fragments are ejected at very high velocities while larger fragments are slower thanks to their larger mass. That video has them all intermixed.
See here: http://www.phinds.com/balloonanalogy/
Keep in mind that the redshift measured increases linearly with the distance of an object. An explosion within space would NOT do this.
At the time of the big bang, everything was in the form of radiation and subatomic particles. A normal explosion would have pushed the lighter particles away faster than the heavier ones and would have had no affect on the radiation.
We routinely measure recession velocities of objects that exceed the speed of light. If it were a normal explosion that caused the expansion this would be impossible per the rules of Special Relativity. Luckily for us General Relativity trumps SR and allows recession velocities to exceed c if they are non-local and due to the geometric properties of space. (IE if they are caused by expansion, not movement through space)
I heard recently that different frequencies of radiation have been measured to travel at different speeds on their way through space to us. Is it possible that this bias in the arrival time of different frequencies could affect our measurement of distances to objects?
A frequency dependent speed of light has been postulated under a variety of cosmological models. No such effect has been detected to date.
Incorrect. Expansion is currently the only thing that explains the observed recession velocities.
Hubble said:
the assumption that redshifts are not velocity shifts is more economical and less vulnerable, except for the fact that, at the moment, no other satisfactory explanation [i.e., apart from the Doppler effect] is known.
There are exceptions to the rule, and unexplained observations with galactic velocity fields that call into question expansion as an explanation of redshift.
But seeing as there are no explanations forthcoming, expansion will have to do as a model for now, although it is fun trying to come up with alternatives, that's for other threads though.
Not according to the glossy TV documentary I watched a couple of weeks ago. They reported well-observed and significant effects and discussed them with the researchers. All quite excited about it. I don't think I dreamt it but you never know.
When discussing science one should always take for granted that if someone says something, the phrase "as far as we know" is implied.
What exceptions are you referring to?
TV documentaries are notoriously prone to giving out highly speculative and often incorrect information. Do not take them seriously unless you can find the same information from multiple sources, preferably peer reviewed sources.
To elaborate on what Drakkith said, here is a constructive suggestion: You say they discussed the findings with the researchers! Another time if you could jot down the names of one or more of those who did the research, we could look their papers up.
It's normally easy to do if you have the name and first initial of one of the authors.
A celebrity scientist merely commenting on some younger person's work isn't usually very helpful. But if you give us the name of one of the researchers we might be able to find the actual scientific publication online.
There have been some false alarms---seemingly exciting results that were not confirmed---so it's helpful to be able to find the particular announcement and publication that they were talking about.
Grounded, are you still around?
The current rate of expansion is 1/139 of one percent every million years. It sounds like you are asking that someone measure the distance to a star to within an accuracy of 1/139 of one percent, and then wait a million years and measure it again that accurately, to see if it is then farther away by that fraction of a percent. :biggrin:
But actually astronomers do better than this all the time! For example with type 1A supernovae.
These are all about the same intrinsic brightness and they follow the same approximate schedule day by day. Changing brightness and color. About 15 days to reach peak brightness, then falling off at a certain rather rapid rate for about 25 days, then dimming at a much more gradual rate for another 40-some days. The color changes are more subtle but detectable---different bands change according to a slightly different profile over time.
With a z=1 supernova of this type, for example, we get the news of its day 5 LATER, because by the time it is doing its day 5 stuff (which is recognizable and we expect) it is FARTHER.
So the news of what it was doing on day 5 only reaches us on day 10. Because it had to travel farther.
We know to expect the peak brightness around day 15, but during the first 15 days of its explosion the star got farther away. So the news had farther to travel and we only get the news on day 30 of watching.
This is essentially what you were asking people do with Cepheids, observe one now and then a while later to see if it has moved farther. Well YES, effectively this is done with that type of supernova.
The watching schedule is retarded (compared with the explosion schedule) by the star getting day by day farther away and the news needing more time to get to us.
the site you linked to says this
if expansion of galaxy clusters are "UNIFORM" in all direction then it is conclusive indication that galaxy clusters are indeed expanding due to metric expansion of space .
http://astro.unl.edu/classaction/animations/cosmology/balloon.swf
but unfortunately that is not the case ,different clusters are expanding itself and moving away from other clusters of the "cosmic web" at DIFFERENT rate
now imagine you blowing a balloon and the pennies glued to the surface of balloon are NOT uniformly moving away from each other ?how weird would that be ?
No, they are not. The RATE is the same for all of them, the VELOCITY is different. Rate is a ratio between two numbers, such as the increase in distance between two galaxies and the time it takes for that to happen. The rate of expansion determines how long it takes for distances between everything to double. Galaxies further away from each other move further away in total distance and have a greater recession velocity, but they end up TWICE as far away at the same time as everything ends up twice as far away.
Yes, this is why I brought it up here.
marcus said:
... With a z=1 supernova of this type, for example, we get the news of its day 5 LATER, because by the time it is doing its day 5 stuff (which is recognizable and we expect) it is FARTHER.
We know to expect the peak brightness around day 15, but during the first 15 days of its explosion the star got farther away. So the news had farther to travel and we only get the news on day 30 of watching. ...
Marcus, Can I just confirm, are you saying that for a particular such explosion, with a particular z, the timing difference between the expected day 5 events and the expected day 15 events is growing at a significant rate (i.e. it can reasonably be observed - not the 1/139% over a million years)?
I would have expected that, for a particular explosion, the difference in timing between the day 5 and day 15 events would have been 10 day plus a tiny (unmeasurable) amount.
Regards,
Noel.
Do you remember the documentary's title (in whole or part)? On what network it was broadcast?
I would love to track it down.
I would have expected that, for a particular explosion, the difference in timing between the day 5 and day 15 events would have been 10 day plus a tiny (unmeasurable) amount.Regards,Noel.
The reason is that the base distance you are calculating a percentage of is large. I will only do a crude approximate calculation using simple percentages.
First, what was the recession rate back at z=1? You know that corresponds to a stretch ratio 1+z which in Jorrie's calculator is called S. In this example S=2 (wavelengths get doubled on their way to us.)
So go here:
http://www.einsteins-theory-of-relativity-4engineers.com/CosmoLean_A25.html
put a 2 in the upper limit box, and press calculate.
You will see that the LOOKBACK time is approximately 8 billion years. This is the time it takes light to reach us from the explosion.
A small fractional change in DISTANCE THEN will correspond to roughly the same small fractional change in Lookback time. Placing an event farther away increases the time it takes light to reach us.
But you will also see that from the same calculator output table that the HUBBLE TIME back then was about 8 billion years.
So when you let one day pass during the explosion distance then increases by the fraction (1 day)/(8 billion years)
And that causes the lookback time to increase by about the same fractional amount.
The lookback time is 8 billion years and the fraction is (1day)/(8 billion years). Multiply the two together and you get 1 day.
So the news reaches us after TWO DAYS, for two reasons: we are watching the second day of the explosion so the event occurred one day later, but also what we are watching was FARTHER by a certain small fractional amount and so the time it took light to reach us was one day more.
The second effect you can think of as a direct experience of expansion. Distances to galaxies increase and so we can compare this way and see that a day later the galaxy we are looking at is a certain amount farther----because the light took longer to reach us.
I only say this to respond to that guy's (Mr. Grounded) OP question. He said could we look at a Cepheid some years later and tell it was farther. I think we could but I don't know of the research. However astronomers also use Supernovae the same way, as distance marker "standard candles". And they are ALWAYS looking at the 60 day lightcurve history of the explosion. And they are ALWAYS seeing that history get stretched out (by Jorrie calculator "stretch ratio" S, or by 1+z if you like). So I'm telling that guy yes we do see this all the time, but with Supernovae, if not with Cepheids. It comes free with them and would be more work and take more time with Cepheids, I think.
The schedule of natural process gets stretched just the same ratio the lightwaves get stretched.
We know the 60 day schedule of Type 1A SN explosion from watching near ones which are not stretched out so much. The Type 1As are all pretty much the same (as you know but the OP Mr. Grounded may not) because they blow at a critical mass and so that is why they are used as standard-brightness "candles" to mark distance.
Marcus, I appreciate that the effect of expansion on the timings of processes is "old hat" to you (and I assume many others) but it is news to me (and I thought that I knew / read a lot on the subject). Much, much appreciated. Wow.
I'll read some more papers on type 1a's, but do you know of other cosmological events, with known process timings, that I could read about to understand it more?
(I have to say, including redshift, the four pillars, etc., this is by far and away the best evidence for expansion that I've come across. I want to consider it further, but wow!)
Again, very much appreciated.
Regards,
Noel.
The universe is expanding. I think what confuses most people (including me, but I think I have a grasp now) is that it is expanding ~like~ it would have expand if it exploded from a big bang (so it is easy without math to say it was "just" an explosion), but everything is moving away from everything else with a force that cannot be explained by the model of an explosion of everything from a central point. That is the expansion that throws you off. This force is weak--too weak to rip apart atoms, so the stuff we are made of is not flying apart and our planet it safe... just getting farther away from far away things faster than local velocities could explain.
What part of the expansion is able to be explained by an explosion within space? To my knowledge it simply isn't able to be explained in such a way. For example, I don't think a normal explosion could explain the linear increase in velocity as distance increases.
J.C. I said it can't be explained. I said to the observer it would looks like that. A bunch of separate stuff getting farther and farther away from each other.
I think I see the issue. You said is expands "like" it would from an explosion. Well, obviously this isn't true, but for someone who hasn't ever seen the data, it can seem like it does. Is that the gist of what you were getting at?
  • · Replies 19 ·
  • · Replies 23 ·
