Lorentz Boost Help: Why Use Hyperbolic Functions?
The discussion centers around the use of hyperbolic functions in Lorentz boosts within the context of special relativity. Participants explore the mathematical transformations that relate time and space coordinates in four-dimensional spacetime, particularly focusing on why hyperbolic functions are employed instead of trigonometric functions.
  • Some participants note that using ordinary sine and cosine functions leads to rotations that can reverse the direction of time, potentially violating causality.
  • Others argue that hyperbolic sine and cosine functions allow for transformations that maintain causality while achieving the necessary shifts in the spacetime coordinates.
  • A participant explains that in the context of spacetime, the geometry is non-Euclidean, and hyperbolic functions preserve the spacetime interval, as shown by the identity cosh²(θ) - sinh²(θ) = 1.
  • Another participant mentions that in four-dimensional spacetime, intervals of constant length correspond to hyperbolas, which may simplify calculations involving hyperbolic functions.
  • Some participants express a desire for additional resources to further understand the topic.
Participants generally agree on the necessity of using hyperbolic functions to avoid causality violations, but there is ongoing discussion about the implications and applications of these transformations.
The discussion highlights the differences between Euclidean and non-Euclidean geometries in the context of spacetime, as well as the mathematical properties of hyperbolic functions that are relevant to Lorentz transformations.
fys iks!
I was reading a section on lorentz boosts and i need some help understanding what they did:
the book starts off by defining the line element dS where:
(dS)^2 = -(CΔt)^2 + dx^2 + dy^2 + dz^2
then they say: "consider the analogs of rotations in the (ct) plane. These transformations leave y and z unchanged but mix ct and x. The transformations with this character that leave the analogies of rotations of (3.9) but with trig functions replaced by hyperbolic functions because of the non euclidean nature of space time. Specifically
ct= [cosh(theta)]*[ct] - [sinh(theta)]*x
x = [sinh(theta)]*[ct] + {cosh(theta)]*x
y= y
z = z
and 3.9 was
x = cos(gamma)*x - sin(gamma)*y
y = sin(gamma)*x + cos(gamma) * y
So what i don't understand is why did they decide to use the hyperbolic functions in 4 dimensions?
If you use a transformation with an ordinary sin and cos in it, you get a rotation. If you keep on rotating the x-t plane, at some point you'll have rotated it so it's 180 degrees upside-down. At that point you've reversed the direction of time. This violates causality.
Thanks! That helped out a lot.
So by using hyperbolic sin/cos they were able to create the same shift without violating causality.
Do you have any links that further explain this in more detail?
You have not been paying attention, have you. An ordinary rotation in 3D space leaves the length of a vector unchanged, where the length element is [itex]ds^2=dx^2+dy^2+dz^2[/itex]. Rotating this by [itex]\theta[/itex] gives in the xy plane gives
[tex] ds'^2= (cos(\theta)dx+sin(\theta)dy)^2+(sin(\theta)dx-cos(\theta)dy)^2+dz^2[/tex]
and because [itex]cos(\theta)^2+sin(\theta)^2=1[/itex] it follows that [itex]ds'=ds[/itex].
In the ct-plane, we wish to preserve [itex]ds^2=dt^2-dx^2-dy^2-dz^2[/itex]. If you do the calculation as above with cosh and sinh instead, you find [itex]ds'=ds[/itex] because [itex]cosh(\theta)^2-sinh(\theta)^2=1[/itex]. The geometry of the cx plane is not Euclidean.
[posted simultaneously with bcrowell]
http://www.lightandmatter.com/area1book6.html
In 4 dimensional spacetime intervals of constant length are hyperbolas. Also it is sometimes easier to work with hyperbolic functions
[tex] tanh(\theta) = v/c[/tex]
The addition of velocities is reduced to adding hyperbolic functions.
  • · Replies 33 ·
