- 24,488
- 15,063
...as measured in ##S## (just to be pedantic ;-)).PeroK said:Yes, as long as you remenber that ##v## is the velocity of ##S'##.
If I throw you another mag I hope and trust that you don't suppose that the difference between uprange and downrange doesn't matter.PeroK said:A boost is a change of reference frame. There is no sense in which one reference frame is moving "away from" or "towards" another reference frame. The relationship is one of relative velocity.
Likewise, the relative velocity of two objects is not defined by whether they are moving towards each other or not. An object may move towards you, past you and away from you, but its relative velocity remains the same throughout.
The sign of the relative velocity (positive or negative) is determined by whether you take the object to be moving in the positive x-direction or negative x-direction; not whether it's moving towards you or away from you.
If velocity is important does this speed apply to the nucleus of the atom?nomadreid said:Summary:: The v and x in the factor (t-vx/c^2) in the Lorentz boost: if v is the speed and x is the distance, then it doesn't matter if the movement is away or towards or anything else, the boost will be the same, but if vx is the dot product of velocity and a spatial position vector, then the direction makes a difference So which is it?
The Wikipedia article on Lorentz transformations is a bit confusing by its using speed and velocity almost interchangeably: of course γ (Gamma) stays the same, but (letting c=1) t'=γ(t-vx) , then if this is v⋅x, and x stays the same, then there would be a difference if something were going away from the other at v or going towards each other at -v. I seem to recall that there is no difference, indicating that the scalars are what is meant, but in the Wiki article, there is a section in which they are, so I am obviously overlooking something.
Why are you asking? What's this atom you are thinking of doing?bill hart said:If velocity is important does this speed apply to the nucleus of the atom?
Unfortunately.Ibix said:I'm afraid that seems to me to be nonsense. If you are attempting to describe a published theory, please provide a reference (preferably a link) to wherever you read it. If you are proposing personal speculation, I recommend that you review the PF posting rules (in short: posting personal speculation is not allowed).
