Undergrad Lorentz Invariance of Q in Weinberg: Justifying Transformation
The discussion centers on the Lorentz invariance of the charge integral ##Q \equiv \int d^3 x J^t(x)##, derived from the four-vector current ##J^{\alpha}(x)## under the condition ##\partial_{\alpha} J^{\alpha}(x) = 0##. The transformation of the normal vector ##n_{\beta}## is justified as it defines the hypersurface for integration, while the integrand quantities ##x## and ##J(x)## remain unchanged. The conclusion is that the total charge is conserved and behaves as a Lorentz scalar, contingent upon the local conservation law being satisfied, as articulated in Weinberg's framework.
  • Understanding of four-vectors in the context of special relativity.
  • Familiarity with the concept of Lorentz transformations and invariance.
  • Knowledge of the delta function and its role in integrals over hypersurfaces.
  • Grasp of the local conservation law ##\partial_{\mu} J^{\mu} = 0## and its implications.
  • Study the implications of the delta function in integrals over spacetime, particularly in the context of hypersurfaces.
  • Explore the derivation and applications of von Laue's theorem in charge conservation.
  • Investigate the mathematical treatment of conserved currents in quantum field theory.
  • Review the "4/3 problem" related to electromagnetic energy and momentum in the presence of charge densities.
The discussion is beneficial for theoretical physicists, particularly those specializing in quantum field theory, as well as students and researchers interested in the foundations of Lorentz invariance and charge conservation principles.
ergospherical
Education Advisor
Insights Author
If ##\partial_{\alpha} J^{\alpha}(x) = 0## then ##Q \equiv \displaystyle{\int} d^3 x J^t(x)## is time-invariant. To show that if ##J^{\alpha}(x)## is a four-vector then ##Q## is also Lorentz-invariant, he re-writes it as \begin{align*}
Q = \int d^4 x J^{\alpha}(x) \partial_{\alpha} H(n_{\beta} x^{\beta})
\end{align*}where ##n_{\alpha} = (1,0,0,0)## and ##H(x)## is the unit step function. I think this makes sense because ##n_{\beta} x^{\beta} = t## and \begin{align*}
Q = \int d^4 x J^{\alpha}(x) \partial_{\alpha} H(t) &= \int d^4 x J^t(x) \partial_t H(t) \\
&= \int d^4 x J^t(x) \delta(t) \\
&= \int d^3 x J^t(x)
\end{align*}The next part is to find ##Q'## under a Lorentz transformation, which he claims is done by changing ##n_{\beta} \rightarrow n'_{\beta} = {{\Lambda}^{\gamma}}_{\beta} n_{\gamma}##. That is, ##Q' - Q = \displaystyle{\int} d^4 x \left[ J^{\alpha}(x)\{H(n_{\beta}' x^{\beta}) - H(n_{\beta} x^{\beta}) \}\right]##. What is the justification for this step - why, for example, is ##n_{\beta}## the only quantity that needs to be transformed in the integrand, and not ##x## or ##J(x)##?
Maybe\begin{align*}
Q' = \int d^4 x' J^{\alpha}(x') \partial'_{\alpha}H(n'_{\beta} x'^{\beta}) \overset{x' \rightarrow x}{=} \int d^4 x J^{\alpha}(x) \partial_{\alpha}H(n'_{\beta} x^{\beta})
\end{align*}because ##x'## is a dummy variable of integration, yes?
ergospherical said:
Maybe\begin{align*}
##x## is not really a dummy variable, no, because of the step function and the contraction with the normal ##n_\beta## in the argument to the step function.
I think the term "Lorentz invariance" may be a bit of a misnomer here. "Lorentz invariance" is usually used to refer to quantities at a single spacetime point, but ##Q## is an integral over a spacelike hypersurface. The "Lorentz transformation" here is really changing which hypersurface is being integrated over (heuristically, by changing the "angle" of the hypersurface in the spacetime). So ##Q'## and ##Q## are integrals over two different hypersurfaces.
The purpose the step function (or more precisely its derivative) serves is to pick out the spacelike hypersurface (or more precisely its "angle"); Lorentz transforming the normal vector ##n_\beta## changes the "angle" of the hypersurface that gets picked out by the delta function derivative of the step function. So the "Lorentz transformation" here is only supposed to operate on ##n_\beta##; it would make no sense to have it also operate on ##x^\beta## or ##J^\alpha##, because those operations would change things other than which hypersurface we are integrating over. See further comments below.
I think it's the reason I just gave above. However, I'm not sure that's the only step that was left out in obtaining the equation for ##Q' - Q##. I think the fact that ##\partial_\alpha J^\alpha = 0## has to come into play somewhere, because without some additional constraint on ##j^\alpha##, beyond it just being a 4-vector, I don't see why ##Q## would be Lorentz invariant--why would an integral over a different spacelike hypersurface at a different "angle" have to give the same answer for any 4-vector? But if ##J^\alpha## has to be divergence free, that additional condition might be enough.
Likes vanhees71
The Lorentz transformation ##Q \rightarrow Q'## should keep the domain fixed, but a change of variables e.g. ##x^{\alpha} \rightarrow x'^{\alpha} = {\Lambda^{\alpha}}_{\beta} x^{\beta}## in the integration (but not a Lorentz transformation) should take the domain ##D \rightarrow D'##. To put the answer back in terms of ##D## requires, say, the tube theorem (assuming ##J(x)## vanishes sufficiently quickly at large distance), right?
That's one possible interpretation (keep the 3-surface the same but change coordinates on the spacetime), but I'm not sure it's the one Weinberg intended. We would expect any integral of the same quantity over the same 3-surface to give the same result regardless of the choice of coordinates, just based on general principles of tensor analysis, so I would not see the point of making a big effort to prove it in a textbook. But if the integrals are over two different 3-surfaces, then it seems reasonable to investigate in a textbook whether they both give the same answer.
No. Remember that the integral over the 3-surface is being obtained from an integral over all of spacetime by using the derivative of a step function. So whatever determines the domain of the integral over the 3-surface has to appear in the argument of the step function. And the thing in that argument that obviously would do that is the normal ##n_\beta##, since by definition that's the normal to the 3-surface, so to change the 3-surface, that is what you would change.
(Note that I say "the 3-surface", but actually ##n_\beta## is a vector field on the spacetime, so what it's actually defining is an entire foliation of the spacetime by 3-surfaces, the ones everywhere orthogonal to ##n_\beta##. The derivative of the step function just picks out the one 3-surface in the foliation whose "time coordinate" in the obvious inertial coordinate chart implied by the foliation is ##0##.)
The total charge in the unprimed frame is ##Q = \int d^3x J^0(x)##, where the integral is carried out at one fixed time ##t## in the unprimed frame. Weinberg shows that ##Q## is independent of the choice of the fixed time ##t##, so we might as well choose ##t = 0##. This picks out the particular hypersurface in spacetime that defines the domain of integration for ##Q##.
Likewise, the total charge according to the primed frame is ##Q' = \int d^3x' J'^0(x')##, where we may choose ##t' = 0## as the hypersurface for this integral. This hypersurface is a different set of spacetime points than the hypersurface ##t = 0##.
Defining ##n_{\alpha} \equiv (1, 0, 0, 0)##, we have
##Q = \int d^4x J^{\alpha}(x)\partial_{\alpha} H(n_{\beta}x^{\beta})##
##Q' = \int d^4x' J'^{\alpha}(x')\partial'_{\alpha} H(n_{\beta}x'^{\beta})##
It's important to note that in these expressions for ##Q## and ##Q'##, ##n_\beta## is the same set of numbers (1, 0, 0, 0) in both integrals. Thus, there is no prime on ##n_\beta## in the expression for ##Q'## above.
Next, we may write the integral for ##Q'## in terms of the unprimed coordinates ##x^\mu## and the unprimed ##J^\mu(x)## via ##x'^\mu = \Lambda^\mu\, _\nu x^\nu##, ##J'^\mu(x') = \Lambda^\mu\, _\nu J^\nu (x)##, and ##\partial'_\alpha = \Lambda_\alpha \, ^\beta \partial_\beta##. It is well-known that ##d^4x' = d^4x## and it is easy to see (or show) that ##J'^\alpha(x') \partial '_\alpha = J^\beta(x)\partial_\beta##. So,
##Q' = \int d^4x J^\alpha(x) \partial_\alpha H(n_\beta \Lambda^\beta \, _\gamma x^\gamma)##
##n_\beta## here still represents the numbers (1, 0, 0, 0). Next, Weinberg defines the quantities
##n'_\gamma \equiv \Lambda^\beta \, _\gamma n_\beta##
This is just a definition. Weinberg is not treating ##n_\beta## as a covariant 4-vector. If ##n_\beta## were a 4-vector then the transformation law would be ##n'_\gamma = \Lambda _\gamma \, ^\beta n_\beta## , which is not the same as Weinberg's ##n'_\gamma = \Lambda^\beta \, _\gamma n_\beta##.
So, with this definition of ##n'_\gamma##, we finally arrive at Weinberg's result
##Q' = \int d^4x J^\alpha(x) \partial_\alpha H(n'_\gamma x^\gamma)##
This integral still represents integration over the hypersurface ##t' = 0##, but it is expressed in terms of the unprimed coordinates and values of the unprimed current ##J^\alpha(x)##.
Finally we have,
##Q'-Q = \int d^4x J^\alpha(x) \partial_\alpha\left[H(n'_\beta x^\beta) - H(n_\beta x^\beta) \right]##
##\partial_\alpha H(n'_\beta x^\beta)## is nonzero only on the hypersurface ##t' = 0## while ##\partial_\alpha H(n_\beta x^\beta)## is nonzero only on the hypersurface ##t = 0##.
Weinberg proceeds from here, with the help of ##\partial_\alpha J^\alpha = 0##, to show that ##Q' = Q##.
Likes ergospherical
Great, thanks! The approach makes sense after having understood the definition of ##n'##.
The notation might be less confusing if we introduce two four-vectors ##n## and ##N## associated with the two hypersurfaces. ##n## is defined by having ##n_\alpha = (1,0,0,0)## in the unprimed frame and ##N## is defined to have ##N'_\alpha = (1, 0, 0, 0)## in the primed frame. Then
##Q = \int d^4x J^\alpha(x) \partial_\alpha H(n_\beta x^\beta) \,\,\,\,## and ##\,\,\,\, Q' = \int d^4x' J'^\alpha(x') \partial'_\alpha H(N'_\beta x'^\beta)##
Writing ##Q'## in terms of the unprimed coordinates and current yields
##Q' = \int d^4x J^\alpha(x) \partial_\alpha H(N_\beta x^\beta)##
Here, ##N_\beta = (\Lambda^{-1})_\beta \, ^\gamma N'_\gamma = \Lambda ^\gamma \, _\beta N'_\gamma##
The components ##N_\beta## have the same values as Weinberg's ##n'_\beta##.
Then ##Q'-Q = \int d^4x J^\alpha(x) \partial_\alpha \left[ H(N_\beta x^\beta) - H(n_\beta x^\beta)\right]##
Likes ergospherical
What Weinberg writes down is just the volume integral over ##\partial_{\mu} J^{\mu}## over a "world tube" enclosing the world line of the particle with two space-like hypersurfaces with the time-like normal vectors ##N_{\beta}## and ##n_{\beta}## as bottom and top boundary surface. Then you use the 4D Gauss's integral theorem to see that ##Q'-Q=0##, where ##Q## (##Q'##) is the charge as calculated in reference frames with ##n^{\beta}## (##N^{\beta}##). This shows that the total charge is a scalar when calculated in this way, i.e.,
$$Q'(t')=\int_{\R^3} \mathrm{d}^3 x' \rho'(t',\vec{x'}) = \int_{\R^3} \mathrm{d}^3 x \rho(t,\vec{x})=Q(t).$$
Using the world tube with boundaries such that ##N_{\beta}=n_{\beta}## this proves that the total charge is conserved. Both results together show that electric charge is conserved and a Lorentz scalar.
It's important to keep in mind that the naive definition of the charge as spatial integrals at fixed time in an arbitrary inertial frame leads only to a Lorentz invariant charge if the local conservation law ##\partial_{\mu} J^{\mu}=0## holds, which is known as "von Laue's theorem".
For a more detailed discussion (applied to a conserved particle-number current rather than the em. current, but the math is of course identical) see pp. 18-19 in
https://itp.uni-frankfurt.de/~hees/publ/kolkata.pdf .
If you naively calculate such integral quantities from non-conserved densities, you easily run into trouble with interpretation. A famous example is the infamous "##4/3## problem" in the definition of electromagnetic energy and momentum at presence of charge and current densities, where of course ##\partial_{\mu} T_{\text{em}}^{\mu \nu}=-F^{\nu \rho} j_{\rho} \neq 0##.
Likes dextercioby, TSny and ergospherical
I am pretty sure this particular problem at hand has been previously addressed by @samalkhaiat here (well, I do not recall if there was the exact argument of Weinberg explained/expanded upon, but the overall „Q is constant” issue).
Likes TSny and vanhees71
  • · Replies 101 ·
  • · Replies 24 ·
