Undergrad Lorentz Transformation: Explaining Invariance of c?
The discussion centers on whether the Lorentz Transformation would change if the invariance of the speed of light (c) were explained rather than postulated. Participants agree that the mathematical derivation of the Lorentz transformation remains unchanged as long as c is constant, regardless of its explanation. The conversation touches on the implications for special relativity (SR) and general relativity (GR), noting that while GR does not use the invariance of c as a postulate, it assumes light travels on null paths. The consensus is that the foundational mathematics of SR and GR would not be affected by a different explanation for c's invariance. Ultimately, the thread concludes with a reminder of forum rules against unverified theories.
DanMP
Please tell me if Lorentz Transformation would be altered in any way if the invariance of c is explained, instead of postulated.
The mathematical derivation of the Lorentz transformation is the same as long as c is constant. It does not depend on why c is constant (explained or postulated).
Great! Thank you.
What about the rest of the math in relativity (both special and general)?
@DanMP I'm not comprehending your question. Can you give some conceptual example to show how you imagine SR or GR might change if a physical cause for constant c were identified?
A potential simple answer is that nothing SR or GR will ever change because they successfully predict within their domains, just like Newtonian mechanics did not change when relativity came on the scene. I might be totally missing your question, though.
The invariance of the speed of light is essentially explained by Maxwell's theory of electromagnetism. Reconciling that theory with Classical Mechanics, in the form of the Galilean transformation, was problematic. The invariance of the speed of light is, however, consistent with the Lorentz Transformation.
You can develop SR from several starting points: invariance of the speed of light; the Lorentz Transformation; the velocity addition formula; to name but three. It doesn't have to be done the way it was first done by Einstein in 1905.
DanMP said:
Great! Thank you.
GR does not have the invariance of the speed of light as a postulate. It does, however, assume that light travels on null paths. But, that is not fundamental to the development of the theory; only to the behaviour of light within the theory.
If I postulate 2+2=4, is that result in any way affected if I, instead, postulate 1+1=2 and treat 2 as derived instead of fundamental?
The only way physics would be affected by an explanation for the invariance of c would be if it turns out that the explanation shows that c isn't invariant. Presumably it would also provide an explanation as to why c is close enough to invariant that we have so far not noticed.
Likes Dale
Maybe I'll post my explanation for the invariance of c. The basic idea is that we rely on atoms/molecules when it comes to measure anything, including time intervals and distances in space (our instruments are made of atoms/molecules), but atoms/molecules are structures held together by electromagnetic forces, with the photon as the force carrier ... So, we are measuring the speed of light using something that depends on it ...
I don't expect that the math of SR or GR would change in any way by replacing a postulate with an explanation stating the same thing, but when I wrote this in another forum, I was not believed, so I'm here to ask for experts opinion.
Work all the way through this line of thought (and "all the way" is a very long hard slog with not much reward at the end) and you will come up with the Lorentz Ether Theory. LET makes the same predictions as special relativity so we can't say that it is exactly wrong; but it is a very poor base on which to build any deeper understanding of general relativity or relativistic quantum mechanics so is generally rejected by physicists.
We have a policy prohibiting discussions of LET here: https://www.physicsforums.com/insights/pfs-policy-on-lorentz-ether-theory-and-block-universe/
I don't quite understand this. The invariance of c is not used/necessary in GR?
So what? You can construct a theory in which there is a finite invariant speed but light does not travel at it (Proca's work). Experiment does not match it. You can construct a theory in which there is no finite invariant speed (Newton). Experiment does not match it. You can construct a theory that does not respect the principle of relativity (ether theories are one such type). Experiment does not match it.
As Nugatory notes, you can construct theories with extra hidden elements that don't change anything, but why bother?
There are no global inertial frames in general relativity, so "the same speed in all inertial frames" doesn't have inertial frames to work with. It's still true locally - light will always pass you at c.
It doesn’t matter why the two postulates hold. Provided they do hold then SR is valid and vice versa
Nugatory said:
Work all the way through this line of thought and you will come up with the Lorentz Ether Theory. LET makes the same predictions as special relativity so we can't say that it is exactly wrong; but it is a very poor base on which to build any deeper understanding of general relativity or relativistic quantum mechanics so is generally rejected by physicists.
No, my explanation has nothing to do with LET. Maybe I'll post it tomorrow.
This is great. It is exactly what my explanation concludes. Thank you!
Don't. That will put you on the wrong side of the Physics Forums rule prohibiting posting theories that have not been previously published in an appropriate peer-reviewed journal.
Likes Dale
This thread is closed
  • · Replies 20 ·
  • · Replies 101 ·
  • · Replies 32 ·
  • · Replies 0 ·
  • · Replies 32 ·
