Lorentz transformations (2nd year relativity)
1 reply · 4K views · last reply
affans
A light signal is sent from the origin of a system K at t = 0 to the point x = 1 m, y = 8 m, z = 13 m. a) At what time t is the signal received?
b) Find ( x', y', z', t' ) for the receipt of the signal in a frame K' that is moving along the x-axis of K at a speed of 0.6c.
The lorentz transformations:
x' = [tex]\gamma * (x - vt)[/tex]
y' = y
z' = z
Part a was easy. I got the right answer. I just took the length of the vector given by the co-ordinates and divided by the speed of light. The answer is [tex]5 * 10^8[/tex] I am having trouble with part b.
Ofcourse, y' and z' were easy to get. t' (i had 3 tries, and i used them all) so I lost a mark there. I have one try left on x'.
Using the equation, we first have to solve for [tex]\gamma[/tex]. Plugging the numbers into the equation for gamma:
[tex]\frac{1}{\sqrt{1-(v/c)^2}}\; \text{yields} \; 1.25[/tex]
Then using the lorentz transformation I have the following eqn:
x' = [tex]\gamma[/tex] (x - vt) . Plugging in the numbers yeilds
x' = 1.25(1 - 0.6 * c *(5E-8))
I get 10 as the answer. It is wrong. I also thought t = 0 could work since that's when the event happened. But the answer 1.25 is also wrong.
My third attempt yielded 11.25m however, I am scared to submit it. If anyone can please verify my number for me.
The Lorentz transformations are more accurately written
[tex]\Delta t' = \gamma(\Delta t - v\Delta x/c^2)[/tex]
[tex]\Delta x' = \gamma(\Delta x - v\Delta t)[/tex]
The [itex]\Delta[/itex] indicates that the numbers to be plugged in should be the difference between two spacetime events. So putting in t=0 is a mistake that you should not make again.
Can you show your calculations for the other two attempts?
