Lorentz transformations of the angular momentum
The discussion focuses on the transformation of angular momentum under Lorentz transformations, highlighting that angular momentum is represented as a rank-2 tensor rather than a vector due to the absence of a cross product in four dimensions. In the center of mass frame, angular momentum can be expressed using the Levi-Civita symbol, allowing for a three-vector representation that simplifies calculations. The transformation of the angular momentum tensor involves specific components and matrices, with off-diagonal elements interpreted as angular momentum. The conversation also emphasizes that angular momentum does not simply contract like length or momentum; rather, it requires understanding the effects of both boosts and rotations in Lorentz transformations. Overall, the transformation of angular momentum is complex and involves careful consideration of tensor properties.
scope
hey,
does anyone there know how the angular momentum (L=r x p) is transformed under Lorentz transformations?
There is no cross product in four dimensions, so the generalization of rxp is a rank-2 tensor, not a vector: J^{jk}=r^jp^k. In the center of mass frame of a system, with the axis taken to be the center of mass, you can define a three-vector Jl according to J^{jk}=\epsilon^{jkl}J^l, where \epsilon is the Levi-Civita symbol. The advantages of Jl are that it's less unwieldy than J^{jk}, and it matches up with the Newtonian angular momentum in the appropriate limit. The advantage of J^{jk} is that it transforms in a simple way, as a rank-2 tensor.
Likes Spinnor
thank you so angular momentum becomes a tensor that is 2 times countervariant? but how are these tensors transformed under Lorentz transformations?
<br /> M^{\mu \nu} \equiv X^{\mu} P^{\nu} - X^{\nu} P^{\mu}, \; M^{\nu \mu} = -M^{\mu \nu}<br /><br /> M&#039;^{\mu \nu} = \Lambda^{\mu}{}_{\rho} \, \Lambda^{\nu}{}_{\pi} \, M^{\rho \pi}<br />
Likes Spinnor
thank you, does that mean that if the length is contracted by k, the momentum is also contracted by k, and the angular momentum by k^2?
In general a Lorentz transformation doesn't reduce to just length contraction and time dilation. I believe the way you've stated it would work if the angular momentum tensor was diagonal, but actually it's the off-diagonal components that are interpreted as the angular momentum.
The matrix corresponding to \Lambda^{\mu}{}_{\nu} uses \mu as a row index and \nu as a column index. For example, for the common relative motion along the Ox_{1}-axis, the matrix is:
<br /> \hat{\Lambda} \rightarrow \left[\begin{array}{cccc}<br /> \gamma &amp; -\beta \, \gamma &amp; 0 &amp; 0 \\<br /> <br /> -\beta \, \gamma &amp; \gamma &amp; 0 &amp; 0 \\<br /> <br /> 0 &amp; 0 &amp; 1 &amp; 0 \\<br /> <br /> 0 &amp; 0 &amp; 0 &amp; 1<br /> \end{array}\right]<br />
where:
<br /> \gamma = (1 - \beta)^{-1/2}, \; \beta = V/c<br />
For the angular momentum tensor, one needs X^{\mu} = (c t, \mathbf{r}) and P^{\mu} = (E/c, \mathbf{p}). Therefore, we can write:
<br /> M^{i 0} = X^{i} \, P^{0} - X^{0} \, P^{i} = x_{i} \, \frac{E}{c} - c t \, p_{i}<br />
i.e. they are the Cartesian components of the vector:
<br /> \frac{E}{c} \, \mathbf{r} - c t \, \mathbf{p}<br />
<br /> M^{i j} = X^{i} \, P^{j} - X^{j} \, P^{i} = x_{i} \, p_{j} - x_{j} \, p_{i} = \epsilon_{i j k} \, L_{k}<br />
where \epsilon_{i j k} is the Levi-Civita completely antisymmetric symbol (\epsilon_{1 2 3} = +1) and L_{k} are the Cartesian components of the angular momentum pseudo-vector \mathbf{L} = \mathbf{r} \times \mathbf{p}.
Likes Spinnor
So, for example, to find how L_{z} transforms under a conventional Lorentz transformation, you should look how M^{1 2} = L_{z} transforms according to the general rule:
<br /> L&#039;_{z} \equiv M&#039;^{1 2} = \Lambda^{1}{}_{0} \, \Lambda^{2}{}_{2} \, M^{0 2} + \Lambda^{1}{}_{1} \, \Lambda^{2}{}_{2} \, M^{1 2} = \gamma \left(L_{z} - \beta \, c (t p_{y} - \frac{E}{c^{2}} \, y) \right)<br />
thank you, but then how is the "contraction factor" of the angular momentum for Lz or any other coordinate, (simply) calculated?
I don't have a clue what a 'contraction factor for angular momentum' means. This is how the components of angular momentum are transformed when we go from one frame of reference to another.
It doesn't reduce to a simple contraction factor. That's the point of #6.
Each Lorenz transformation can be composed of space rotations and a simple boost. It is clear how angular momentum transforms under simple space rotations. So, it remains to look for a simple boost affecting only, say, x and t coordinates. Then the contraction factor is the standard one.
The only problem is that the angular momentum is a 2-fold (antisymmetric) tensor, so it carries two Lorentz indices and you might perform a rotation with respect to one of them and a boost with respect to the other.
Likes Spinnor
That is not a problem, because even when it has two indices, the same Lorentz transformation acts on both of them, not two different.
No, it's a rank-2 tensor. It doesn't transform like a rank-1 tensor. Write out the tensor transformation law for a simple case, and you'll see that the result looks nothing like what you'd have for a 4-vector.
A tensor transforms under the tensor product of the representation. There is nothing mysterious about it. 2-tensor transforms with R\otimes R where R is the vector (or -co-vector) representation. Then there can be covariant and contravariant tensors. For a covariant tensor you need to take the contragradient representation - that's all.
Or, in simple terms, each index transforms with the same transformation matrix (perhaps a contragradient one).
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 101 ·
  • · Replies 54 ·
