LRC Circuit: Frequency of Oscillation determined by R
The discussion focuses on determining the resistance needed to adjust the frequency of a pure LC circuit, specifically with an inductance of 340 mH and a capacitance of 2200 pF. The required frequency change is 0.10 percent, leading to the conclusion that the resistance must be calculated using the formula R=(((w-w')^2-w^2)4L^2)^1/2, where w' represents the new frequency. The analysis confirms that the addition of resistance will decrease the frequency, as K is less than one, resulting in a new angular frequency of 0.999 ω0.
  • Understanding of LC circuit fundamentals
  • Knowledge of angular frequency and its relationship with resistance
  • Familiarity with critical damping conditions in oscillators
  • Ability to manipulate algebraic equations symbolically
  • Study the effects of resistance on oscillation frequency in RLC circuits
  • Learn about critical damping and its implications in circuit design
  • Explore the derivation of angular frequency in damped oscillators
  • Investigate the practical applications of LC circuits in electronics
Electrical engineers, physics students, and anyone involved in circuit design or analysis, particularly those focusing on oscillatory behavior in LC circuits.
jamesbiomed
How much resistance must be added to a pure LC circuit (L = 340 mH, C = 2200 pF) to change the oscillator's frequency by 0.10 percent?
Will the frequency be increased or decreased?
I'm assuming critical damping: R^2=4L/C, w=((1/LC)-R^2/(4L^2))^1/2
With no R: w=(1/(LC))^1/2
I've been at this for a few hours :/ I'm letting w stand in for frequency since w=2pif the percent change needed for f should be the same for w (I hope). I've tried several approaches:
First, I tried w=(1/LC)^1/2 to get w. Then multiplied w by .001 to get .1%. Then made an equation: w-((1/LC)-R^2/(4L^2))^1/2=.001w
That didn't work, but the answer was close to the given one.
I also tried simply setting .001w=(1/LC-R^2/2l^2)^1/2 and that answer was further off.
If I'm missing anything or you need information I'd be happy to give it I'm really enthusiastic to get this done. Thank you in advance!
The angular frequency of a damped oscillator is
\omega=\sqrt{\frac{1}{LC}-\left(\frac{R}{2L}\right)^2}
Your first approach is correct, but it would be easier to write ω=K√(1/LC). How much is K? less then 1 or greater then 1? Then you can square both sides. Do it symbolically, do not evaluate. ehild
Hey echild. The problem was I wasn't squaring k, just plugging it in after the fact.
K is less than one, so the frequency should be decreased.
For anyone with same problem:
w' is .1 % w.
w'=k(1/LC)^1/2=> (w')^2=k^2/LC=>(w')^2=(.001)^2/(LC) so omega is the square root of that.
Then w-(w^2+(R/2L)^2)^1/2=w'. Solve for R:
R=(((w-w')^2-w^2)4L^2)^1/2. That solved it.
Thank you!
I meant that the new angular frequency is 0.999 ω0, where ω0=1/√(LC).
So
\omega=\sqrt{\frac{1}{LC}-\left(\frac{R}{2L}\right)^2}=0.999\sqrt{\frac{1}{LC}}
Squaring both sides:\frac{1}{LC}-\left(\frac{R}{2L}\right)^2=0.998\frac{1}{LC}
0.002\frac{1}{LC}=\left(\frac{R}{2L}\right)^2
ehild
  • · Replies 21 ·
