Lyapunov exponent - order of magnitude
The discussion focuses on the calculation and interpretation of the Lyapunov exponent in chaotic systems, specifically in the context of a chaotic pendulum. A calculated Lyapunov exponent of approximately 10^5 was deemed excessively high, particularly if the oscillation frequency is around 1Hz, where a more typical value would be around 0.1 s-1. The conversation emphasizes the importance of calculating the Lyapunov spectrum, which involves analyzing multiple dimensions of the system's phase space, rather than relying solely on pairs of distant points in time. For accurate analysis, the method of Takens embedding theorem is recommended to derive additional dimensions from a 1-D time series.
  • Understanding of Lyapunov exponents and their significance in chaotic systems
  • Familiarity with phase space and its dimensions
  • Knowledge of Takens embedding theorem for reconstructing phase space
  • Basic principles of chaos theory and nonlinear dynamics
  • Study the method for calculating the Lyapunov spectrum in chaotic systems
  • Learn about the Takens embedding theorem and its application in time series analysis
  • Explore the algorithm by Eckmann and Ruelle for Lyapunov exponent calculation
  • Read "Nonlinear Dynamics and Chaos" by Steven Strogatz for practical insights into chaos theory
Researchers, physicists, and engineers working with chaotic systems, as well as students studying nonlinear dynamics and chaos theory.
dudy
Hello,
Analyzing data from a chaotic pendulum, I calculated the Lyapunov exponent to be somewhere around 10^5 . While my gut tells me something is wrong with this number , i failed to find any information regarding the order of magnitude of Lyapunov exponents and their meaning.
Can someone give me a "feeling" for different magnitudes of Lyapunov exponents, or a place I can get a less theoretical and more practical read about them?
Thank you
Science news on Phys.org
That value does seem far too large, unless the typical frequency of the oscillations are in the 100kHz range. The Lyapunov exponent just tells you the rate at which two close trajectories diverge (e.g. two simulations of the pendulum with slightly different initial conditions). Due to the exponential divergence in chaos, the effect doesn't usually become noticable until after several cycles of the system.
If the oscillating frequency is ~1Hz and the Lyapunov exponent is ~105s-1 then trajectories would diverge well before a single cycle. In this case it becomes very hard to define the attractor of the system. I imagine you'd need a huge number of dimensions so that trajectories wouldn't come back on themselves too quickly. A more "normal" value for the Lyapunov exponent would be ~0.1s-1.
By the way, what method are you using to calculate the exponent? For a thorough analysis you'll typically have to calculate the Lyapunov spectrum i.e. the exponent for each of the dimensions. The reason is that trajectories will diverge at different rates or even converge depending on the direction in phase space.
Hope that helps. If you need any more info then have a read of the book Nonlinear dynamics and chaos by Steven Strogatz; it explains lots of things with pictures and nice non-mathematical descriptions.
First of all thank you very much for the reply- it is extremely helpful.
About the method I'm using- What I did is to take two points from my data that are far apart on the time-line, but have very close values, and watch how the difference (of values) between them grows with time. I repeated this process with different pairs of points.
In light of your reply I'm guessing this is not the right way to go about it, but- why? I mean, I thought I was pretty much calculating the Lyapunov exponent "by definition" this way.
Yes, you're right, that is exactly how the Lyapunov exponent is defined. The reason why it's not usually calculated this way is because the exponent only defines local behaviour for bounded systems (i.e. ones that come back on themselves to form cycles). If the divergence due to the Lyapunov exponent held true for all time then the system wouldn't have an attractor, there would just be a series of exponential trajectories moving towards +/- infinity.
The standard method for calculating the Lyapunov spectrum is to plot a single trajectory of the system in phase space. This assumes you have outputs of the system for all dimensions (for chaos there should be at least 3) - if not then you can just use Takens embedding theorem on a 1-D time series to get the extra dimensions. You can then use the algorithm by Eckmann and Ruelle (http://pra.aps.org/abstract/PRA/v34/i6/p4971_1" ).
