Maclaurin Series f(x) = (2x)/(1+x2)
The Maclaurin series for the function f(x) = (2x)/(1+x²) can be derived using polynomial long division, resulting in the series 2x - 2x³ + 2x⁵ - 2x⁷ + ... This series can also be expressed as a summation: ∑[(-1)ⁿ2x²ⁿ⁺¹] for n=0 to ∞. The coefficient of x²⁰⁰⁷ in this series is -2, leading to the conclusion that f²⁰⁰⁷(0) = -2 * 2007!. This approach simplifies the process compared to calculating multiple derivatives.
  • Understanding of Maclaurin series and Taylor series expansions
  • Familiarity with polynomial long division
  • Basic knowledge of calculus, specifically derivatives
  • Ability to manipulate infinite series and summations
  • Study the derivation of Taylor series for various functions
  • Learn polynomial long division techniques in calculus
  • Explore the properties of infinite series and convergence
  • Investigate the relationship between derivatives and series coefficients
Students studying calculus, particularly those focusing on series expansions, mathematicians interested in function approximations, and educators teaching Maclaurin series concepts.
jacoleen
Write the Machlaurin series for :
f(x) = (2x)/(1+x2)
I tried finding all the derivatives (aka f(x), f'(x), f''(x), etc..) but the equations started getting longer and longer and would always result in 0 when x=0. This was on a final exam last year, and I don't think they would have made students do long computations like that
Also, I tried just finding the derivatives for (1-x)-1, but again, I ended up with a bunch of zeros
Help?
Hmmm... I'm not sure, but would it be cheating to use that
1 + r + r^2 + r^3 + \cdots = \frac{1}{1-r}
for |r| < 1?
If you do that, you wouldn't need any calculus at all (except for the uniqueness of Maclaurin series).
I was thinking of doing that in the first place, but on another exam there was a similar question and part c was Find f^2007(0) :(
In that case, you can work backwards, because the coefficient of xn in the series gives you \frac{f^{n}(0)}{n!}
so my series would just be: Summation of [(-1)n2x2n+1]?
I'm not sure how I would work backwards though :|
Usually, you would compute \frac{f^{2007}(0)}{2007!} to find the coefficient of x2007 in a Maclaurin series. But in this case, you know the coefficient. What does that tell you about \frac{f^{2007}(0)}{2007!} ?
I'm really not getting it..
do i isolate for f(2007) by equating it to the summation? (without the summation term in front)
You're on the right track. What is the coefficient of x2007 in this problem?
the summation divided by x^-2007?
* without the negative
Actually, you found that
\frac{2x}{1+x^2} = \sum_{n=0}^{\infty}(-1)^n2x^{2n+1}
When you write out the summation, you get
\frac{2x}{1+x^2} = 2 x-2 x^3+2 x^5-2 x^7+2 x^9-2 x^{11} + \cdots
From this, can you find the coefficient of x2007?
is it just -2?
(i'm so sorry I logged off btw, my computer overheat :(
Yep!
Now remember that the Maclaurin series of f(x) can be found by:
f(x) = \frac{f(0)}{0!} + \frac{f'(0)}{1!} x + \frac{f''(0)}{2!} x^2 + \frac{f'''(0)}{3!} x^3 +\cdots
So the coefficient of x2007 must be
But you know that the coefficient is -2. So what does this tell you about f2007(0)?
it's equalled to 2?..and so f(2007) = 2*2007!?
Close! It's actually f(2007)(0) = -2 * 2007!, but I think you got the idea. ;)
OMG..it actually makes sense!
Thank you so much for your help! :D
f(x) = (2x)/(1+x2)
Help?
If all you need to do is get the Maclaurin series for 2x/(1 + x^2), there's something you can do that's much simpler than what I've seen in this thread - just polynomial long division to divide 2x by 1 + x^2. Doing this, I get 2x - 2x^3 + 2x^5 -...
  • · Replies 48 ·
  • · Replies 16 ·
  • · Replies 16 ·
