Magnetic field and current tendency
The discussion focuses on calculating the current tendency in a two-wire system with a distance of 10 cm between them, where the upper wire carries a current of I1 = 6A. The calculated current in the bottom wire (I2) is determined to be 2A when the magnetic field at point P is zero. The participants also discuss finding equivalent magnetic field points Q and S, emphasizing the need to analyze magnetic field lines and vector components for accurate calculations.
  • Understanding of Ampère's Law and magnetic fields
  • Familiarity with vector addition in physics
  • Knowledge of trigonometric functions for resolving vectors
  • Experience with magnetic field calculations involving parallel currents
  • Study Ampère's Law and its applications in magnetic field calculations
  • Learn about vector addition and decomposition in physics
  • Explore the concept of magnetic field lines and their significance
  • Investigate the effects of varying distances between parallel current-carrying wires on magnetic fields
Physics students, electrical engineers, and anyone interested in electromagnetic theory and applications involving current-carrying conductors.
ayalala
1. Two-wire, long, straight parallel 10cm distant from each other, as shown in the chart.
Upper wire current issue I1 = 6A trend into the top level.
A. What are the strength of the current tendency I2 bottom wire, if the magnetic field equivalent at P equal Zero?
b. What is the equivalent magnetic field point? Q
C. What is the equivalent magnetic field point S?
2. not sure what to use
3. a) B[tot]=B1-B2=0
B1= μ0I1/ 2π*0.15
B2= μ0I2/ 2π*0.05
μ0I1/ 2π*0.15 = μ0 I2/ 2π*0.05
6/0.15= I2/0.05
0.3=0.15 I2
I2=2A
b) ??
c)B=√B1^2+B2^2 (?)
Thank you very much for your help.
(b) Just do the same setup as you did for (a) except swap the distances for the two current carrying wires.
(c) Not sure what you are doing, but it is best if you draw the magnetic field lines from each wire at point S. That way you will know how to add the vectors.
Thank you.
So basically for B it should be the same answer?
As for c:
If I understand correctly I need to "break" te view of each wire at point S and then:
B1(x access)=Bcosθ
B1(y access)=Bcosθ
then find vector for B1
same for B2
and to add them both?
(b) Won't be the same answer, but you would solve it in a similar fashion as (a).
(c) You are right that you need to break the magnetic field up into its components for B1 and do the same for B2. Be careful with the trigonometry. I am not sure what angle you choose, but make sure you use the correct sin and cos.
Solved
Thx.
