Magnetic field and respecetive force
The discussion revolves around the relationship between the magnetic field of a permanent magnet and the force exerted on a ferromagnetic material placed within that field. Participants explore various formulas and concepts related to magnetic fields, forces, and the behavior of ferromagnetic materials, with a focus on both theoretical and experimental aspects.
  • Experimental/applied
  • Some participants clarify that "metal" should refer specifically to "ferromagnetic" materials, such as iron.
  • A participant describes an experiment with rare Earth magnets and nails, noting the complexities involved in measuring forces and the influence of magnetization on ferromagnetic materials.
  • One participant proposes a formula for the force on a magnetic dipole in a magnetic field, suggesting that the force can be expressed as F = ∇(m·B), where m is the magnetic dipole moment and B is the magnetic field.
  • Another participant points out that the magnetic dipole moment of an unmagnetized ferromagnetic material will depend on its position within the magnetic field, leading to a modified expression for force.
  • There are discussions about the gradient of the magnetic field and how it affects the force experienced by the ferromagnetic material.
  • Participants express uncertainty regarding how the magnitude of the magnetic field changes over space and the implications for calculating forces.
  • Several requests for visual references and sketches of magnetic fields are made, indicating a need for better understanding of field strength and force directions.
Participants do not reach a consensus on the best approach to relate the magnetic field and force, with multiple competing views and formulas presented. The discussion remains unresolved regarding the exact nature of the relationship and the appropriate models to use.
Limitations include the dependence on the specific properties of ferromagnetic materials, the complexity of the magnetic field's spatial variation, and the need for precise definitions of terms used in the discussion.
This discussion may be of interest to those studying magnetism, ferromagnetic materials, or anyone conducting experiments related to magnetic fields and forces.
joao_pimentel
Magnetic field of a permanent magnet and respecetive force
Hello
I just want you to explain me a bit of physics, cause I am a lay.
How to relate (which formula) the magnetic field of a permanent magnet, the vector B at each point (x,y,z), with the force applied to a certain particle of metal, with no speed, within that field?
Thank you
It is complicated
"Metal" is not interesting - I guess you mean "ferromagnetic" (only some materials are ferromagnetic, iron is the most relevant example)
sorry. Yes I meant a ferromagnetic material like iron for example.
Can you give me any formula or reference?
Thank you
See the link in my post.
mfb said:
It is complicated
I think it's even more complicated than that. That link is about forces between magnets.
I just did an experiment with my 1 Tesla rare Earth magnets and a pair of nails.
The nails weigh about 1/2 gram, are 1.5 cm long, 2 mm in diameter, and were originally not magnetized.
The magnet is a smooth edged cube, the edges measuring roughly 4.1 mm.
The magnet is able to lift a nail off the table from a distance of 1 cm.
The magnet nail combination was not able to life the 2nd nail from the table until the distance was ≈1 millimeter.
When the magnet was removed from the first nail, the nails stayed attached. I had created magnets!
Trying to determine the strength of the residual nail flux density, I was only able to determine that a separation of 0.1 mm resulted in nail #1 not being able to support nail #2.
The last measurement I did, was to remove the magnet, flip the poles, and slowly bring it towards the nails. When the magnet was 2.5 cm from nail #1, nail #2 was released. I'm guessing that the field strength of the two nails can be deduced from this measurement. (Perhaps I should turn this problem over to micromass, for another "Math Challenge" :-p )
The nails were still both magnetized after this portion of the experiment, as each could support the others weight.
But introducing unmagnetized nail #3, neither was able to budge it.
Anyways, the problem with this problem, as I see it, is that the magnetization of the ferromagnetic material is influenced, and changed by the permanent magnets, making this a really dynamic problem. If I flip the poles of the permanent magnet, and bring it to the two nails, their magnetic fields reverse.
Problems with this experiment:
Like many nails, these had flat heads and pointy tails. Geometry is probably critical.
When I find my dremel tool, I'll redo the experiment.
So I suppose this is my answer
[tex]\mathbf{F}=\nabla \left(\mathbf{m}\cdot\mathbf{B}\right)[/tex]
where [itex]\mathbf{m}[/itex] is the vector of the magnetic dipole moment, which has the direction from south pole to north magnetic pole.
I suppose as well that [itex]\mathbf{B}[/itex] at each euclidean point is the tangent of all those lines we see going around the magnet.
http://upload.wikimedia.org/wikipedia/commons/b/bb/Magnetic_field_due_to_dipole_moment.svg
Can you provide me any image with the forces at each euclidean point, considering that [itex]\mathbf{m}[/itex] doesn't change neither direction nor magnitude, as it is not intuitive to calculate the dot product and the respective gradient?
Thank you
PS: Please correct me if anything is wrong
PS: I can see that close to poles, F is higher as m is aligned with B (cross product is maximum) and there is a great change in B, which provokes the gradient to be high in magnitude, but it would be nice to see one picture of the vector F at each point :)
Can you give any reference?
Thanks in advance
@joao_pimentel: Careful, m is from one object and B is from the other object.
If your piece of iron/steel is not magnetized initially, its m will depend on the position. As an approximation, it will be proportional to B coming from the magnet (as long as B is not too strong, ~2T for iron/steel).
This leads to ##F=\nabla (cB^2) = 2c B \nabla |B|## (check this!)
Looking at the dimensions, I expect that c is a multiple of V/µ0 where V is the volume of the magnet and µ0 is the vacuum permeability. There might be a factor of µr missing somewhere.
##F=\nabla (cB \mathbb{.}B)=\nabla (c|B|^2)=c\nabla (|B|^2)=c\sum_{k=1}^3\frac{\partial (|B|^2)}{x_k}\mathbb{\vec{e_k}}=c\sum_{k=1}^3 2 |B|\frac{\partial (|B|)}{x_k}\mathbb{\vec{e_k}}=2c|B|\sum_{k=1}^3 \frac{\partial (|B|)}{x_k}\mathbb{\vec{e_k}}=2c|B|\nabla (|B|)##
Considering ##2c|B|## a real positive number, the only term which will change the direction of ##F## is ##\nabla|B|##. Though, I cannot see how ##|B|## changes over space, because those lines in the pictures don't give notion of magnitude of ##B##
With a good sketch and as a rough estimate, a high line density corresponds to a large |B|.
For a real magnet, you need some map of the field strength.
http://magician.ucsd.edu/Essentials_2/WebBook2ch1.html#x3-50001.3 looks reasonable for a bar magnet. As you can see, the magnetic field is very strong close to its poles, and weaker elsewhere.
Hi, thank you very much for reference, nevertheless I suppose I won't be able to trace the directions of F at each point. I'll continue searching if I find anything
