mfb said:
It is complicated
"Metal" is not interesting - I guess you mean "ferromagnetic" (only some materials are ferromagnetic, iron is the most relevant example)
I think it's even more complicated than that. That link is about forces between magnets.
I just did an experiment with my 1 Tesla rare Earth magnets and a pair of nails.
The nails weigh about 1/2 gram, are 1.5 cm long, 2 mm in diameter, and were originally not magnetized.
The magnet is a smooth edged cube, the edges measuring roughly 4.1 mm.
The magnet is able to lift a nail off the table from a distance of 1 cm.
The magnet nail combination was not able to life the 2nd nail from the table until the distance was ≈1 millimeter.
When the magnet was removed from the first nail, the nails stayed attached. I had created magnets!
Trying to determine the strength of the residual nail flux density, I was only able to determine that a separation of 0.1 mm resulted in nail #1 not being able to support nail #2.
The last measurement I did, was to remove the magnet, flip the poles, and slowly bring it towards the nails. When the magnet was 2.5 cm from nail #1, nail #2 was released. I'm guessing that the field strength of the two nails can be deduced from this measurement. (Perhaps I should turn this problem over to micromass, for another "Math Challenge"
The nails were still both magnetized after this portion of the experiment, as each could support the others weight.
But introducing unmagnetized nail #3, neither was able to budge it.
Anyways, the problem with this problem, as I see it, is that the magnetization of the ferromagnetic material is influenced, and changed by the permanent magnets, making this a really dynamic problem. If I flip the poles of the permanent magnet, and bring it to the two nails, their magnetic fields reverse.
Problems with this experiment:
Like many nails, these had flat heads and pointy tails. Geometry is probably critical.
When I find my dremel tool, I'll redo the experiment.
