Magnetic Field at a point due to two parallel wires
3 replies · 9K views
smithisize
Two long parallel wires are a center-to-center distance of 4.90 cm apart and carry equal anti-parallel currents of 3.70 A. Find the magnetic field intensity at the point P which is equidistant from the wires. (R = 10.00 cm).
http://imageshack.us/a/img11/3812/twoparallelwires.jpg
dB = μo*I*(dL[itex]\vec{}[/itex]xdR[itex]\vec{}[/itex])/(4*pi*r^3)
Well first I tried multiplying the equation for magnetic field of an infinite line (μo*I/(2*pi*r) by two since there are two wires. then I realized that since the current is flowing in opposite directions, the y-component of the field, so to speak, would cancel out, and now I'm stuck.
Here is the solution, but I want to know how to arrive here (and more specifically I'd like to know why we're multiplying the infinite line equation by the y-component): d*I*μo/(2*pi*(R^2+ (d/2)^2)
hi smithisize! :smile:
smithisize said:
… then I realized that since the current is flowing in opposite directions, the y-component of the field, so to speak, would cancel out …
no, if you draw a vector diagram (with arrows), you'll find the x components cancel out :wink:
tiny-tim said:
hi smithisize! :smile:no, if you draw a vector diagram (with arrows), you'll find the x components cancel out :wink:
Well, the vector equations for dr are R[itex]\hat{i}[/itex] -(d/2)[itex]\hat{j}[/itex] and R[itex]\hat{i}[/itex]+(d/2)[itex]\hat{j}[/itex] therefore the vector sum states that the vertical component cancels out.
But, I ended up figuring it out. If you draw the b-field for the top wire, and manipulate theta (of the upper left corner of a triangle drawn on the top wire) a bit, you can end up with the proper configuration and see that where it all comes from.
no, if you draw the arrows, you'll see that one goes to the left, and the other to the right,
so it's -R[itex]\hat{i}[/itex] +(d/2)[itex]\hat{j}[/itex] and R[itex]\hat{i}[/itex]+(d/2)[itex]\hat{j}[/itex] :wink:
