Magnetic field H from a current loop in Matlab
4 replies · 2K views
jadelsky
Hey all. I have a little problem in Matlab. I attached word file in this post where the problem is explained because I can't write those formulas here.
It's not hard, just need to put few formulas together. I also wrote what i tried, but the result is not good. I calculated it manually and the result in Matlab isn't as expected.
I'm calculating magnetic field H in x-y plane due to current loop and I need to see how the field is changing according to radius of loop. I also wrote in word file what is expected, the result from one book, and results I calculated manually are very similar to those in that book.
If anyone can take few minutes, take a look and try to help me I wold be grateful. :)
Just one correction
K=1/E is not correct, it should be K=(1/E)*(pi/2)^2
The following code seems to work:
clear all;clc;
h=0;
a=1;
I=1;
r=0:1e-2:a;
k=sqrt((4*a*r)./((r+a).^2+h^2));
E=(sqrt(1-k.^2))*(pi/2);
K=(1./E)*(pi/2)^2;
H1=I/2*pi*sqrt((r+a).^2+h^2);
H2=K+(2*a*(r+a)./(((r+a).^2+h^2).*(1-k.^2))-(1./(1-k.^2))).*E;
H=H1.*H2
plot(r, H);
grid on;
xlabel('r(m)')
ylabel('H(A/m)');
You made a mistake with the parenthesis of the sqrt for the lowercase 'k'
I corrected it and saw a functional dependence of something similar to what you have shown.
The y-axis values may not be right, but they depend on your parameters anyway...
Hope it helps...
Yes, thank you very much...it's something like thaht, but I don't get why the values for H are so much bigger than expected...for example in 0 I'm sure that H needs to be 0,5 and on this graf it is 10 times bigger...the funcion looks allright, but this results are confusing...
finally...it's ok...stupid mistake...now it is as it should be :)
