Magnetic field in a closed path
7 replies · 2K views · last reply
Faefnir
Find (a) the module and (b) the direction, entering or exiting the page plane, of the magnetic field at point P, knowing that a = 4.7 cm and i = 13 A
Biot-Savart law
For 1-2 and 4-5 segments, B = 0 because sin θ = 0 for all segment points.
Taking the 2-3 segment
R = distance from P to the wire (2-P line)
r = distance from P to the point 3. Assume the point 3 as the infinitesimal segment ds (3-P line)
s = wire length (2-3 line)
From the first rectangle triangles law
R = r sin (π-θ) = r sin (θ) ⇒ sin (θ) = R/r
r is triangle's hypotenuse with s and R as catetis
r2 = R2 + s2
Solving the integral
after a few steps
Regardless of the numerical result, the final formula I got is right, or have I made any mistakes?
Thanks in advance
kuruman said:
What about the magnetic field from segments 5-6 and 6-1?
Is this both of them or just one? What about the total? What about the direction?
Both of 5-6 and 6-1.
About total and direction:
2-3 is entering
6-1 is exiting
Not sure about horizontal segments (3-4 and 5-6): Can you help me? (yes, I know sounds like ready-made food)
I supposed to rotate the image by 90° clockwise:
3-4 is entering
5-6 is exiting
So, the total is -1.86 · 10-5
The book reports 20 μA for a entering current (from chapter 29 exercises, Halliday-Resnick-Walker, Electromagnetism and Optics, 7th edition)
Faefnir said:
-1.86 · 10-5
Can you show me how you got this number? Please use the final equation with symbols that you used.
Do you actually mean μA? If so, what current is this?
Solved. Taking ds verse agrees as the one of the current
so
|B| ≅ |-2 · 10-5| T ≅ 2 · 10-5 T
The minus sign suggests an entering direction for the magnetic field
I agree with your answer. Now that you have solved your problem, I will show you an easier way than calculating the separate contributions from each segment. Suppose you found an expression for the B-field at the corner of a regular square. The field for the loop in the problem is the superposition of two squares one of side ##2a## and counterclockwise current and one with side ##a## and clockwise current (see figure below). So once you find the expression for the square, you reuse it for the smaller square with a negative sign because the current is reversed.
