Magnetic Field Inside a Charging Capacitor
The discussion focuses on calculating the magnetic field strength inside a charging parallel-plate capacitor with a diameter of 10 cm and a spacing of 1.0 mm, where the electric field is increasing at a rate of 1.4×106 V/m·s. The correct formula to use is derived from Maxwell's equations, specifically \(\oint B \cdot ds = \mu \epsilon \frac{dE(t)}{dt} A\). The initial attempt yielded an incorrect magnetic field strength of 7.2E-13 T due to misapplication of the area in the integral, highlighting the importance of using the correct area enclosed by the integral.
  • Understanding of Maxwell's equations
  • Familiarity with parallel-plate capacitor configurations
  • Knowledge of magnetic field calculations
  • Proficiency in calculus, particularly integrals
  • Study the derivation of Maxwell's equations in electromagnetic theory
  • Learn about the behavior of electric fields in capacitors
  • Explore the relationship between changing electric fields and induced magnetic fields
  • Practice solving problems involving magnetic fields in dynamic electric fields
Students studying electromagnetism, electrical engineers, and physicists interested in the behavior of magnetic fields in capacitors and dynamic electric fields.
Plasmosis1
A 10-cm-diameter parallel-plate capacitor has a 1.0 mm spacing. The electric field between the plates is increasing at the rate 1.4×106V/m*s.
What is the magnetic field strength 2.7cm from the axis?
\ointB*ds=\mu\epsilondE(t)/dt*A
B=(\mu\epsilondE(t)/dt*A)/(2\pir)
B=(\muId)/(2\piR2)*r
I tried using the first equation:
8.85E-12*4\piE-7*1.4E6*\pi(0.05)2/(2\pi*0.027)=
7.2E-13T which is wrong
"A" should be the area your integral encloses, not the total area of the capacitor.
  • · Replies 16 ·
17K
