Magnetic Field near a curving infinite wire in 3d space
The discussion focuses on calculating the magnetic field at the point (0,0,1) due to a three-dimensional infinite wire carrying a current I0. Participants suggest using the Biot-Savart Law and the formula |B| = μ0I/2πr for the magnetic field of a current-carrying wire. The solution involves finding the magnetic fields of individual wire segments and combining them appropriately. The discussion concludes with the user successfully collaborating with classmates to arrive at a solution.
  • Understanding of the Biot-Savart Law for magnetic fields
  • Familiarity with the formula |B| = μ0I/2πr for infinite wires
  • Knowledge of vector calculus for integrating magnetic fields
  • Basic concepts of electromagnetism and current-carrying conductors
  • Study the Biot-Savart Law in detail, including its applications
  • Learn how to calculate magnetic fields from finite wire segments
  • Explore vector calculus techniques for integrating magnetic fields
  • Review examples of magnetic field calculations for complex wire configurations
Students in physics, electrical engineering, and anyone interested in electromagnetism, particularly those tackling problems involving magnetic fields from current-carrying wires.
speedofdark8
Problem as given: A three-dimensional wire of infinite length carries a current I0 starting at (-∞,0,0) along a straight line to (0,0,0), bending and traveling along a straight line to (0,1,0), then bending and traveling to (0,1,1) and finally bending and traveling out to (∞,1,1). Determine the magnetic field at (0,0,1).
Possibly using |B| = μ0I/2∏r ? Not sure whether/how to combine the fields of the different segments using this general formula for the B-field of a current carrying wire.
I haven't seen a problem like this in our class, so I'm mostly fishing for a start. I am aware of finding the magnetic B field of a current carrying wire using the equation above, but we never talked about a wire oriented in space with coordinates as such. To start, I would assume the wire is bent at a 90 degree angle at each given point where applicable, find the magnetic field of each segment, and from there I am not too sure where to go.
welcome to pf!
hi speedofdark8! welcome to pf! :smile:
yes, find the individual fields, and add them :wink:
integrate the Biot-Savart law for the short sections
(you can probably see how to get it from B = μoI/2πr for the long sections)
I am not familiar with the Biot Savart Law. For the other sections though, would I be correct with the equation I posted earlier?
Thank you for the replys. I have since gotten together with some classmates and we found a solution.
