Magnetic field of a current loop
MahalMuh
Circular current loop with radius of R = 0.3 cm and current I = 1.4 A
Calculate the magnetic field B within the distances of a) x1 = 0.17 cm and b) x2 = 2.3 cm from the axis.
B = (u0/2) * (IR^2) / (x^2 + R^2)^(3/2)
This should be pretty straightforward and my take gives B = 0.000193*T for a) and B = 0.00000063 T for b).
Or have I misunderstood something?
I’m not passing the grader with the above answer.
It seems the B equation is for its x-directed component. To derive B just need the angle. Solved.
MahalMuh said:
[Calculate the magnetic field B within the distances of a) x1 = 0.17 cm and b) x2 = 2.3 cm from the axis.
"From the axis"? Should be "from the coil plane"? Or a diametric axis?
"The axis" is usually understood to be the coil's major axis.
