Magnetic field of a finite-length wire
The discussion centers on the calculation of the magnetic field around a finite-length wire carrying current I. Participants clarify that Ampere's Law cannot be applied due to the lack of symmetry in the magnetic field when the wire's length L is not significantly greater than the distance r from the wire. The correct approach involves using Biot-Savart's Law, which accounts for the finite length of the wire and yields the magnetic field B as B = μ₀I/(2πR) * (L/sqrt(L² + R²)). This formula demonstrates that the magnetic field behaves differently for finite wires compared to infinitely long wires.
  • Understanding of Ampere's Law and its limitations
  • Familiarity with Biot-Savart's Law
  • Knowledge of magnetic field concepts and cylindrical symmetry
  • Basic calculus for evaluating integrals
  • Study the derivation of the magnetic field using Biot-Savart's Law for finite-length wires
  • Explore the implications of magnetic field symmetry in various configurations
  • Learn about the differences in magnetic field calculations for finite versus infinite wires
  • Investigate advanced applications of Ampere's Law in high-symmetry scenarios
Physics students, electrical engineers, and professionals involved in electromagnetic field analysis will benefit from this discussion, particularly those interested in the behavior of magnetic fields around current-carrying conductors.
Chen
Let's say I want to calculate the magnetic field at a distance d from the center of a wire of finite length L, carrying a current I. Why would it be wrong to apply Ampere's law to a circular path of radius d centered on the wire, and say that the integral of B.dl is simply B times 2pi*d? (obviously it gives the wrong answer...)
Is the magnetic field not constant along this circular path? I would say so - the problem obviously has cylindrical symmetry.
Is it not parallel to the path at all points? I would think so - from Biot-Savart's law applied to every small element of the wire.
So where is the mistake in this logic?
Thanks,
That makes a lot of sense, Chen. Do you happen to know what B is around a "short" current carrying wire? It would be interesting to see how it is different from the B for an infinitely long one. I would expect a slightly smaller answer due to the "missing" length on either side.
Looks to me like the finite length L in the Biot-Savard Law gives you a factor of
L/sqrt(L^2 + r^2). Anyhow it goes to 1 as L goes to infinity.
Interesting, but it does not answer your question of why Ampere's Law cannot be applied to the finite length! If you find the answer, I hope you will let me know.
There is a formula here:
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/MagneticField/MFStraitWire.html
If we limit our discussion only to the center of the wire, theta=phi and you obtain the result of an infinite wire, times cos(theta). And I am not at all sure where in Ampere's law this factor comes from. There is probably some fine print that I'm missing here.
dB = u*i/(4*pi)*sin(A)*dx/r^2 where x runs from -L/2 to L/2, sin(A) = R/r
and r = sqrt(x^2 + R^2)
Here R is the distance from the wire center to the point we are computing B for.
B = u*i/(4*pi)*integral R*dx/(x^2 + R^2)^1.5
B = u*i/(4*pi*R)*[x/sqrt(x^2 + R^2)] evaluated between -L/2 and L/2.
B = u*i/(2*pi*R)*L/sqrt(L^2 + R^2)
This is from the standard derivation for the infinite wire, with only the integral limit being changed to -L/2 to L/2.
Thanks. But I know how to calculate this with Biot-Savart's law. I want to know where the application of Ampere's law to this problem fails.
Ampere's Law is only useful in calculating B for situations with very high symmetry. When calculating B of an infinite wire using Ampere's law we choose our path to be a circle around the wire so that B will always be tangent to our path. If the length of the wire isn't large compared to the distance r where we calculate B, this assumption is no longer valid (the B field is no longer symmetric in this way).
In short your assumption that a finite wire's B field has cylindrical symmetry is not correct--the effects of the ends make the field lines shaped oddly and not in a way Ampere's Law can work for us.
