Magnetic field of a moving charged particle
33 replies · 9K views
Or maybe your just not getting the answer provided to you.
There is no magnetic field of a moving particle in it's own frame of reference if I even can call it so.
The magnetic field is only to a observer which moves at a different speed than that of the moving particle or is stationary with respect to it.
there is no difference from a static electric field to that of a particle because the field of a single charged particle is fixed in value and is static if that is what you wanted to know.
There is a difference between the electric field of a static charge and a moving charge. Again, I point to the Lienard Wiechert fields:
http://en.wikipedia.org/wiki/Liénar...onding_values_of_electric_and_magnetic_fields
In these equations the velocity as a fraction of the speed of light is given by ##\beta##. Thus, the case of a non-accelerating charge is given by ##\dot{\beta}=0## while the case of a stationary particle is given by ##\beta=0##. Even if you don't follow the meaning of the equation you can clearly see that it is a function of ##\beta## which means that the field depends on the velocity.
Without even looking at the solution, this clearly cannot be true. Faraday's law and Gauss's law read ##\vec{\nabla} \cdot \vec{E} = 4\pi \rho## and ##\vec{\nabla} \times \vec{E} = -\frac{1}{c}\partial_t \vec{B}## so clearly the solution for an arbitrarily accelerating charge (time-varying delta function source) is in general different from the solution for the special case of a static charge, which simply has ##\vec{\nabla} \cdot \vec{E} = 4\pi Q\delta^3 (\vec{r} - \vec{r}')## and ##\vec{\nabla} \times \vec{E} = 0## where ##\vec{r}'## fixed.
sorry wrong button .:)
