How Does a Compass React to a Current-Carrying Wire?
The discussion focuses on the interaction between a current-carrying wire and a compass, specifically analyzing the magnetic field generated by the wire. The magnetic field due to the wire is calculated using the formula B(wire) = 10^-7(2*I)/r, where 'I' is the current and 'r' is the distance from the wire. The horizontal component of the Earth's magnetic field is approximately 2e-5 tesla, and the net magnetic field (Bnet) is derived from the sum of the Earth's magnetic field and the wire's magnetic field. The calculated magnetic field due to the wire at a distance of 2.9 cm is found to be 3.08532e-7 tesla.
  • Understanding of electromagnetic theory, specifically Ampère's law.
  • Familiarity with magnetic field calculations and vector addition.
  • Knowledge of the formula for the magnetic field around a long straight conductor.
  • Basic proficiency in unit conversions, particularly between centimeters and meters.
  • Calculate the current (I) flowing through the wire using the derived magnetic field values.
  • Explore the effects of varying distances from the wire on the magnetic field strength.
  • Investigate the implications of the compass deflection in relation to the Earth's magnetic field.
  • Learn about the applications of magnetic fields in electrical engineering and physics.
Students studying electromagnetism, physics educators, and anyone interested in the practical applications of magnetic fields in current-carrying conductors.
demonhunter19
A long current-carrying wire, oriented North-South, lies on a table (it is connected to batteries which are not shown). A compass lies on top of the wire, with the compass needle about 3 mm above the wire. With the current running, the compass deflects 10 degrees to the West. At this location, the horizontal component of the Earth's magnetic field is about 2e-5 tesla.
What is the magnitude of the magnetic field at location A, on the table top, a distance 2.9 cm to the East of the wire, due only to the current in the wire?
B(wire)=10^-7(2*I)/r
Bnet = Bearth + Bwire
I know Bearth = 2e-5, and taking into account that Bnet would be the deflection, I obtained 2.0308e-5 for Bnet, and hence, Bwire would equal to 3.08532e-7. I don't really know where to go from here.
Thanks in advance.
Well, you've calculated Bwire at r=3mm, so what does that make I? what does that make bwire at r=2.9cm?
Edit- you might also want to show us your calculation of Bnet, because I don't think it is correct.
