Magnetic field strength between two wires
The discussion focuses on determining the direction of current flow in two parallel wires to achieve a non-zero magnetic field strength at the midpoint between them. Wire 1 has a current of 1A directed into the page, while wire 2, positioned 20 cm to the right, must also have a current flowing into the page to create a counterclockwise magnetic field. This configuration prevents the magnetic fields from canceling each other out. The magnetic field strength at a point on the line joining the two wires is described by the equation B = μo iD / π (D² − d²), where D is the distance between the wires and d is the distance from the midpoint.
  • Understanding of the right-hand rule for magnetic fields
  • Familiarity with magnetic field equations, specifically B = μo i / 2πd
  • Basic knowledge of current flow in parallel wires
  • Ability to manipulate algebraic expressions involving distances and magnetic fields
  • Study the right-hand rule for magnetic fields in greater detail
  • Learn about the derivation of the magnetic field equation B = μo iD / π (D² − d²)
  • Explore the effects of varying current directions on magnetic field interactions
  • Investigate applications of magnetic fields in engineering and physics
This discussion is beneficial for physics students, electrical engineers, and anyone interested in electromagnetism and the behavior of magnetic fields around current-carrying conductors.
victoriafello
wire 1 has a current of 1A directed into the page, wire 2 is 20 cm to the right of wire 1 with a current of 1A, what direction does this current have to flow in order for the magnetic field strength at the mid point between them to be non zero ?
from the right hand rule the mag field from wire 1 would be counterclockwise around the wire so the current on wire 2 would have to be the same direction - into the page with a counterclockwise field other wise the fields would cancel
do i haev this correct & did i explain myself properly ? the next part of the Question depends on this answer
The current into the page gives a clockwise field via the right hand rule, if I'm not mistaken. Draw a picture, I think you came up with the wrong conclusions.
thanks for pointing that out, i have drawn a picture of the wire and i can see now that the current is clockwise, so i think that the current in the other wise also needs to be into the page otehrwise they will cancel,
the next part of the question is -
Consider a general point on the line joining the two wires and a distance d away from the mid-point O. By summing the magnetic field due to currents of magnitude i flowing in both the wires in the senses you found.
show that, on the line joining the two wires, the magnetic field strength is given by
B= μo iD/ PI (D^2 − d^2 )
I know the equation is
B = μo i / 2*pi*d
and (D^2-d^2) can become (D+d)(D-d) but i don't know where to go from there
