Magnetic Field with three parallel wires
Three parallel wires carrying equal currents experience magnetic forces due to their interactions. Wire B is said to experience the greatest net force because it is influenced by both wires A and C, resulting in a net force of 2I^2/d. In contrast, the forces on wire A and wire C partially cancel each other out, leading to a net force of zero on wire A. The discussion emphasizes understanding the direction of forces based on the nature of the currents, with A and B acting positively and C negatively. Clarifying these interactions is crucial for solving the problem accurately.
rikinmathur
Three long, straight wires are carrying currents that have
the same magnitude. In C the current is opposite to that
in A and B. The wires are equally spaced. Each wire experiences a net force due to the other two wires. Which
wire experiences a net force that has the greatest magnitude?
A =====>====
B=====>====
C=====<====
FAB = μ°I1 I2 / 2∏d
It says that the answer is B because 2I squared / d is the net force on B. But the way I am doing it is -I^2/d + I^2/d = 0, hence the net forces cancel out and the force on B is zero. I don't understand how it is 2I^2/d. Please help.
Hi rikinmathur! Welcome to pf! :smile:
What are the direction of forces on wire B due to the other two wires?
Hey rikinmathur, just think in terms of charges, maybe this is easier for you: A and B are positively charged (in a magnetic sense) and C is negative. So, which wire-pairs will experience an attractive and which a repulsive force?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
