Magnetic Fields and wires question
The discussion focuses on calculating the magnetic field at a midpoint between two parallel wires carrying currents of 10A and 20A, spaced 1.0m apart. When the currents flow in opposite directions, the total magnetic field is calculated by adding the currents, resulting in B = 1.2E-5 T. Conversely, when the currents flow in the same direction, the fields oppose each other, leading to a magnetic field of B = 4.0E-6 T. The right-hand rule is essential for visualizing the direction of the magnetic fields generated by the currents.
  • Understanding of Ampère's Law
  • Familiarity with the right-hand rule for magnetic fields
  • Knowledge of magnetic field equations, specifically B = µ(I/2πr)
  • Basic concepts of current flow in parallel wires
  • Study the application of Ampère's Law in different configurations of current-carrying conductors
  • Explore the right-hand rule in various electromagnetic scenarios
  • Investigate the effects of varying current magnitudes on magnetic field strength
  • Learn about the superposition principle in electromagnetism
Students studying electromagnetism, physics educators, and anyone interested in understanding the principles of magnetic fields generated by current-carrying wires.
rss14
Calculate the magnitude of the magnetic field at a point midway between two long, parallel wires that are 1.0m apart and have currents if 10A and 20A, respectively, if the currents are a) in opposite directions, and b) in the same direction.
µ = 4*pi*10^-7
B = µ(I/2*pi*r)
I figured out HOW to do it, just not WHY.
r = 0.5m (because the point is between the wires)
For
a) You add the currents, so the current will be 20A + 10A = 30A. This will give the correct magnetic field, B = 1.2E-5 T.
b) You subtract the current, so the current is 20A - 10A = 10A. This will give the correct magnetic field, B = 4.0E-6 T.
Why does it work this way?
This this have anything to do with it:
When the currents are in the same direction, the magnetic fields oppose each other.
When the currents are in the opposite direction, the magnetic fields add onto each other?
(Use the right hand rule to picture this)
Yes you have answered your own question. The fields do combine as you have deduced and can be pictured (as you have noted), using the right hand rule.
