Magnetic Fields from Current Carrying Wires
The discussion focuses on calculating magnetic fields generated by current-carrying wires, specifically addressing the limitations of the formula B = μ0 * I/(2 * π * d) for long wires. The Biot-Savart law is established as the appropriate method for calculating magnetic fields from shorter wire segments. The derivation of the magnetic vector potential (A) and its relationship to the magnetic field (B) is provided, emphasizing the use of current density (J) and integration over the wire's cross-section. This discussion clarifies that the Biot-Savart law is universally applicable, including for shorter wire segments.
  • Understanding of magnetostatics
  • Familiarity with the Biot-Savart law
  • Knowledge of magnetic vector potential (A)
  • Basic calculus for integration
  • Study the derivation of the Biot-Savart law in detail
  • Learn about magnetic vector potential (A) and its applications
  • Explore current density (J) calculations in various wire configurations
  • Investigate the implications of wire geometry on magnetic field strength
Physics students, electrical engineers, and anyone involved in electromagnetic field theory or applications related to current-carrying conductors.
gibberingmouther
I've had a lot of problems that involve a segment of current carrying wire, for example when you have a square loop of wire.
I have a formula for "long" wires that is B = μ0 * I/(2 * π * d).
Can I use this for shorter wire segments, and if not, what formula can I use?
It depends on where you want to find the field relative to the segment.
On edit: See here for a derivation.
A universal way to get the magnetic vector potential (##\mathbf{A}##), given the current density (##\mathbf{J}##) in magnetostatics is:
##\mathbf{A}(\mathbf{r})=\frac{\mu_0}{4\pi}\int d^3 r' \frac{\mathbf{J}(\mathbf{r}')}{\left|\mathbf{r}-\mathbf{r}'\right|}##
Where integration is over the whole space. To get the magnetic field you simply take the curl
##\mathbf{B}(\mathbf{r})=\boldsymbol{\nabla}\times\mathbf{A}(\mathbf{r})=-\frac{\mu_0}{4\pi}\int d^3 r' \mathbf{J}(\mathbf{r}')\times\boldsymbol{\nabla}\frac{1}{\left|\mathbf{r}-\mathbf{r}'\right|}=\frac{\mu_0}{4\pi}\int d^3 r' \mathbf{J}(\mathbf{r}')\times\frac{\left(\mathbf{r}-\mathbf{r}'\right)}{\left|\mathbf{r}-\mathbf{r}'\right|^3}##
Now define ##\mathbf{R}=\mathbf{r}-\mathbf{r}'## and integrate over the corross-section of the wire, assuming the wire is thin (comapred to ##R##). This will convert the volume integral into integral along the wire: ##\int d^3 r' \mathbf{J}(\mathbf{r}')\to\int dl I(l) \mathbf{\hat{l}}## where ##I## is current (i.e. current density over the whole cross-section of the wire) and ##\mathbf{\hat{l}}## is parallel to the wire (along the direction of current flow).
Thus:
##\mathbf{B}(\mathbf{r})=\frac{\mu_0}{4\pi}\int dl I(l) \boldsymbol{\hat{l}}\times\frac{\mathbf{\hat{R}}}{R^2}##
Now ##\mathbf{R}## points from the section of the wire (at position ##l##) towards the observer. This is the Biot-Savart law. It works in all cases, including shorter wires, your formula its special case.
  • Sticky
  • · Replies 0 ·
  • · Replies 27 ·
  • · Replies 61 ·
  • · Replies 20 ·
