Magnetic Flux Linkage: Rate of Change & Cutting
The discussion centers on the relationship between magnetic flux linkage and the induced electromotive force (e.m.f.) in electromagnetic systems. It establishes that both the rate of change of magnetic flux linkage and the cutting of magnetic flux contribute to the induction of e.m.f. Specifically, inserting a conductive plate into a magnetic field alters the magnetic flux due to the generation of Eddy currents, which in turn affects the magnetic field strength and path. The concept of flux linkage is defined as the connection between the flux path and its strength through the windings of an electromagnet.
  • Understanding of electromagnetic induction principles
  • Familiarity with Eddy currents and their effects
  • Knowledge of magnetic flux and flux linkage concepts
  • Basic principles of electromagnetism and solenoids
  • Study the principles of electromagnetic induction using Faraday's Law
  • Explore the effects of Eddy currents in conductive materials
  • Learn about the role of permeability in magnetic fields
  • Investigate applications of flux linkage in electrical engineering
Students and professionals in physics, electrical engineering, and anyone interested in the principles of electromagnetism and their practical applications.
Ivore
Hi, this may be really easy but..
I understand that to have an induced e.m.f , we can either have a rate of change of magnetic flux linkage ( ac source ) or cutting of flux ( like a plate oscillating and cutting through a magnetic field produced by a solenoid ). However does cutting of flux creates a rate of change of magnetic flux linkage ? Is rate of cutting of flux the same as saying rate of change of magnetic flux ? Or are they both different ?
Whenever you insert a conductive, moving plate in a magnetic field ( induced by an electromagnet ) the magnetic field will be weakened and will change it's path, also through the electromagnet. Thus the flux will be changed through ( some of ) the windings due to Eddy currents in the the plate, that will induce a counter mmf.
Flux linkage is the connection between the flux path and flux strength through the windings.
Even if you insert a non moving iron plate, the magnetic field will be changed steady state due to change of permeability in the surroundings of the magnet.
  • · Replies 19 ·
  • · Replies 16 ·
