Magnetic flux through triangular ring
The discussion focuses on calculating the magnetic flux (ψ) through a triangular ring surrounding a long wire carrying current I. The formula derived is ψ = (μ° I h) / (2∏b - a ln((a+b)/b)). Participants attempted to integrate the magnetic vector potential and the magnetic field B, leading to confusion regarding the correct formulation. A consensus emerged that the denominator in the logarithmic term should be 'a' instead of 'b', as this aligns with the expected behavior of the formula as 'b' approaches zero.
  • Understanding of magnetic flux and vector potential
  • Familiarity with integration techniques in calculus
  • Knowledge of magnetic fields generated by current-carrying wires
  • Experience with logarithmic functions in mathematical equations
  • Study the derivation of magnetic flux through different geometries, focusing on triangular cross-sections
  • Learn about the application of the Biot-Savart Law in calculating magnetic fields
  • Explore advanced integration techniques, particularly triple and double integrals
  • Investigate the implications of boundary conditions in electromagnetic theory
Students and professionals in physics and electrical engineering, particularly those studying electromagnetism and magnetic field calculations.
Ngineer
Very long wire carrying current I is surrounded by a brass ring of a triangular cross section. (figure attached)
Show that ψ =
Code:
μ° I h
------   (b - a ln ((a+b)/b)
  2∏b
A = (μ°I/2∏ * ln x) az (according to one of the solutions, where x is the distance between wire and surface)
ψ = ∫A.dl
First attempt:
My first approach was to integrate the magnetic vector potential over the volume of the the ring, I defined the distance from the wire to the surface as:
d(x,z) = a + b(z/h) + x {0<= z<= h and 0<=x<=b(1 - z/h)
where
z is the rise in the z axis
x is the distance through the surface of the ring (i.e. distance penetrated through the surface)then I took ψ as a triple integral of
z from 0 to h
x from 0 to b(1-z/h)
θ from 0 to 2∏,
of °I/2∏ * ln d(x,z)) az * dxdydθ
but I got a wrong answer
Second attempt
I took only the surface in consideration, i.e. removing all mention of θ. Still couldn't reach the original formula.
I spent almost 4 hours trying to figure this out. I looked up an online solution (out of genuine interest to know how the problem is solved, not academic dishonesty) and after a lengthy process they reach a different formula and claim that this is the solution!
This is really puzzling me because it looks rather simple, like I'm missing a basic formula or something.
Any help is greatly appreciated! Thanks!
Hello, Ngineer.
Note that finding "the total number of magnetic flux lines in the ring" is equivalent to finding the total magnetic flux through the triangular cross-section of the ring.
So, use the expression for the magnetic field B of a wire and integrate B over the triangular cross-section.
The answer given doesn't appear to me to be correct. You would expect the answer to go to zero as b goes to zero while keeping a and h constant.
[EDIT: I believe the b in the denominator of the logarithm should be a.]
Likes 1 person
Yeah. I also just did it using B=μ°I/2∏r and doing a double integral with z on the inside going from 0 to (h/b)(r-a) and r going from a to a+b. The result I got was nearly the same as expected except that I also found the denominator inside the logarithm is a and not b.
Likes 1 person
  • · Replies 21 ·
