Magnetic force on a rigid semicircular wire
26 replies · 9K views · last reply
Maxwellkid
A rigid wire carrying a current I, consists of a semicircle of radius R and two straight portions of length L. The wire lies in in a plane perpendicular to a uniform magnetic field B. The straight portions are also within the magnetic field. Determine the net force due to B on the wire.
F1 = IL1 x B
F2 = IL2 x B
F3 = dF = I dL3 x B
can somebody help me start this problem off correctly by converting these vectors into a uniform coordinate system so that I cab take this simple integral?
B = <0, 0, -Zb>
Welcome to PF.
Consider that the plane of the loop is perpendicular to the magnetic field.
Where will the forces from the B field necessarily be, that is in what direction?
LowlyPion said:
Welcome to PF.
The forces for the two straight portions are easy.
F1 = <0, IL, 0> x <0, 0, -zB> = -IL(zB) i
F2 = <0, -IL, 0> x <0, 0, -zB> = IL(zB) i
F3 = dF3 = I dL x B
this is where I am stuck!
Also, do magnetic fields of north or south pole attract or repel either a positive or negative charge??
F3 = dF3 = I dL x B
Is the wire in a closed loop?
Or is it shaped like the outline of a derby hat?
I don't have the advantage of seeing any diagram.
the rigid wire goes like this. straight up...then forms a semi circular curve...then straight down... no closure stated.
OK. So what direction are the forces on each of the 2 || segments?
What happens when you add them together?
the two parallel section forces cancel each other out. I'm not sure about the upward force. I must take the integral, but I'm a bit stuck.
What upward force are you considering?
the upward force due to the semi circle that connects the 2 parallel sections of the overall wire. F3
So long as you mean upward in the y direction and not out of the paper in z , as there is no force in the || direction to the B field. The cross product will only yield x,y forces. (The plane of your wire.)
Since the semi-circle is symmetrical, then you can ignore any x-directed forces, taking x to be perpendicular to the straight wires.
So maybe set up an integral of just the y-component recognizing that you can express the Force component in y as R*sinθ, where θ is the angle with the x axis. From 0 to π, since it is a semi-circle should do it don't you think?
that's what I've been trying to do...
dF3 = IdL x B how does the integral of dF3 equal to the integral of Rsin@ d@?
Note that your F3 can be written as
dF3(θ) = |dF3|cosθ i + |dF3|sinθ j
but by symmetry for each positive directed |dF3|cosθ i you have on the other side of the mid-line a negative |dF3|cosθ i component. This resolves itself into
dF3(θ) = |dF3|sinθ j
F3(θ) = ∫ |dF3|sinθ dθ , evaluated from 0 to π
This force is all y-directed, since all x-directed force has canceled with each other.
Isn't there another way to set this integral up? Can I convert all this into spherical coordinates?
I'm asking this because step by step I'm not sure how to get to above after I write down the equation dF3= IdL x B. B = <0, 0, -Bz>. IdL= <? , ?, ?>
Why would you want to do that?
Have you evaluated the integral of Sinθ from 0 to π yet?
Why try to thrash about on it?
Yes, and I got -2.
What I'm wondering is this step:
dF3= dF3 cos@ i + dF3 sin@ j. = IR d@ x B
IR d@ =<?, ?, ?>
B = <0, 0, -Bz>
Maxwellkid said:
Yes, and I got -2.
IR d@ =<?, ?, ?>
B = <0, 0, -Bz>
OK so you know then that the vertically directed force in the j direction is going to be proportional to 2R. (The same as if you had a straight wire 2R long bridging the same gap.)
The i components, if you were to evaluate that integral will be the integral of cosθ from 0 to π, which looks to me to be 0. I ignored their contribution, recognizing from symmetry that for each wire element with +i directed force, there is an equal and opposite -i directed force element. The sum of all those will be 0.
I'm not sure how (IR d@ x B) distributes into dF cos@ i + dF sin@ j
(IRd@ x B) cos@ i + (IRd@ x B) sin@ j
How would you evaluate this integral?
Thanks for pointing out the symmetry that cancels out the I component. I see that, but I don't see the technique to evaluate the j component
Perhaps I see your confusion.
Note I wrote my force component equation based on the cross product already taken. I was expressing the components of the force on the individual wire elements as a function of θ from intuition. Then taking the integral.
I think the current-wire elements are originally directed as <I*sinθ, I*cosθ, 0> This gets crossed with <0, 0, B*k>
I think this results in <B*I*cosθ, B*I*sinθ, 0> which I integrated to give
<0, 2R*B*I, 0>
I don't see the above. This is true: Sin@ = I/R. Or sin@= L/R. R= radius of semicircle
Maxwellkid said:
I don't see this. Sin@ = I/R. Or sin@= L/R. R= radius of semicircle
Aren't those the tangential elements of the circle ... along the direction that the current is flowing?
Please re read post 21 sir. Thank you
Thank you Pion!
Do magnetic fields attract or repel charges? If I were to have a static electron next to the North pole of a magnet with no acceleration from both the charge nor the magnet, will I produce any force?
Maxwellkid said:
Thank you Pion!
The interaction is with moving charges and magnetic fields, or changing fields and creating electric potentials that move charges. An electron suspended next to a magnet would be oblivious I would think, as long as it didn't move.
