Magnetic force to hold machine and required Torque to drive
The discussion revolves around the forces acting on a robot crawler with a magnet, specifically the magnetic force needed to hold it against a vertical steel wall and the torque required to drive it upwards. It is clarified that static friction acts upwards to counteract gravity, enabling the robot to remain in place or accelerate upwards. The magnetic force is horizontal, essential for generating the necessary friction that allows the robot to adhere to the wall. The participants emphasize the importance of understanding the direction of forces, particularly how friction must counteract gravity for stability. Overall, the interaction of these forces is crucial for the robot's operation on a vertical surface.
Chilu1234
The robot crawler has a magnet attached to it. The idea is to get the crawler up the wall.
What is the magnetic force required to hold a object (in this case) a robot crawler with an attached Magnet?
Is more magnetic force required to hold the crawler while it goes up the wall?
What is the Torque required to drive the robot crawler up the vertical steel wall while overcoming gravity and magnetic force.
Sum of forces with x and y-axis is 0
and Torque based on Radius of wheel and friction force
3. The Attempt at a Solution
I have made a PDF file of the problem setup and variables and my solution.All formula I used is also there. I hope someone take a look at it and tell me if OK
If friction and gravity both act downwards, how can the robot stay in place or even accelerate upwards as those are the only external forces?
The robot is not sliding, you have static friction.
Likes Chilu1234
@mfb .
Are you saying the friction acts in the same direction of wheel motion? I did not fully understand your comment. Please clarify. sorry for the trouble.
I am 100% that gravity acts downwards. But don't understand friction direction?
Also, there is a magnet attached to the robot that is suppose to pull the machine to the vertical steel wall.
There are two vertical forces acting on the robot: gravity and friction. If the robot is not accelerating, their sum has to be zero. Gravity is pointing downwards, so friction has to point upwards.
If the robot is accelerating upwards, the net force has to point upwards, so you need even more friction pointing upwards.
That is a horizontal force only. It is necessary to get friction, of course.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
