Magnetic Force with Parallel currents
6 replies · 4K views · last reply
Ignitia
A circuit with current I has two long parallel wire sections that carry current in opposite directions. Find magneticfieldatapointPnearthesewiresthatisadistance a from one wire and b from the other wire as shown in the figure.
Rfq8TXpsSAspAbOVLmbWEmTJjR6Ch4mY58sLIzdEgq27Vi71B5IowR~2HwbeoM_&Key-Pair-Id=APKAJ5Y6AV4GI7A555NA.jpg
B=μo*I / 2πR
Field for I1:
B1 = μo*I / 2πb
Field for I1:
B2 = μo*I / 2πa
First have to calculate the x and y components:
Bnetx = B2 [ - sin(θ)] + B1 [cos(0)] = B2 [ - sin(θ)] + B1
Bnety = B2 [cos(θ)] + B1 [sin(0)] = B2 [cos(θ)]
cos(θ) = sqrt(a2 - b2) / a
sin(θ) = b/a
And find the total net value, Bnet = sqrt( Bnetx2 + Bnety2) so,
Bnet = sqrt( ( (μo*I / 2πa) [ - b/a] + (μo*I / 2πb))2 + (( μo*I / 2πa) [sqrt(a2 - b2) / a])2 )
And I just simplify this whole mess, correct? If it's correct up to here, then my mistake is only in the simplifying, and not the steps leading up to it.
  • Rfq8TXpsSAspAbOVLmbWEmTJjR6Ch4mY58sLIzdEgq27Vi71B5IowR~2HwbeoM_&Key-Pair-Id=APKAJ5Y6AV4GI7A555NA.jpg
B=μo*I / 2πR
Field for I1:
B1 = μo*I / 2πb
Field for I1:
B2 = μo*I / 2πa
sin(θ) = b/a
Correct up to here, didn't check the last line. Actually your answer is Bnetx and Bnety since B is a vector with x and y components. Your way calculates the magnitude of the net B field but actually that was not explicitly asked for.Bnet = sqrt( ( (μo*I / 2πa) [ - b/a] + (μo*I / 2πb))2 + (( μo*I / 2πa) [sqrt(a2 - b2) / a])2 )
And I just simplify this whole mess, correct? If it's correct up to here, then my mistake is only in the simplifying, and not the steps leading up to it.[/QUOTE]
Your steps are correct
Charles Link said:
It looks correct to me. What answer did they give?
The answer was
B = μo*I*a/2πb2
I got it down to
B = μo*I/2π * sqrt(a2-3b2)/ab
So if everyone says what I posted is correct, then the logic is fine and I just have to find the mistake leading up to the answer.
Ignitia said:
The answer was
B = μo*I*a/2πb2
I got it down to
Edit: I get ## B=(\frac{\mu_oI }{2 \pi})(\frac{\sqrt{a^2-b^2}}{ ab}) ##. Unless we all made the same mistake, I think the book just might have an incorrect answer. ## \\ ## Also the book's answer makes no sense. When ## a ## is large, their answer becomes large. ## \\ ## For large ## a ##, you get ## B=\frac{\mu_o I}{2 \pi \, b } ## , just as you should. (The ## 3b^2 ## doesn't work for ## a \approx b ##. I originally had the same answer too, until I double-checked the last step).
The book could be wrong - it's happened before. Thanks for checking.
