Is there a type of powder that can attach to iron objects like a magnet?
  • Context: High School
  • Thread starter Thread starter roineust
    Iron Magnetic Powder
The discussion centers on the existence of a powder that can magnetically adhere to iron objects, contrary to conventional magnetic powders like iron filings. Participants clarify that magnetic monopoles do not exist, and while iron filings can be magnetized, they tend to clump together. The conversation also explores the potential for creating a magnetic putty or liquid that possesses a self-sustaining magnetic field after drying, rather than relying on external magnets. Suggestions include experimenting with magnetite powder and Hall effect sensors to investigate magnetic properties.
  • Understanding of magnetic properties and materials
  • Familiarity with Hall effect sensors
  • Knowledge of ferromagnetic materials, specifically magnetite
  • Basic principles of magnetism and magnetic fields
  • Research the properties of magnetite powder and its applications
  • Learn about Hall effect sensors and their use in detecting magnetic fields
  • Explore the formulation of magnetic putty and its components
  • Investigate the principles of creating self-sustaining magnetic materials
Researchers, materials scientists, hobbyists interested in magnetism, and anyone exploring innovative applications of magnetic materials.
roineust
Does any kind of magnetic powder exist?
I mean not iron powder, that is attracted to a magnet but vice versa, a type of powder, that when i take an iron nail or screw and get it close to that powder, the powder will attach itself to that iron object and stay there, for as long as it is not taken off.
If there was, what would keep it from sticking together in a lump?
Great answer. But if I were to isolate a single powder particle, then it should also exist as a dipole.
If you found a particle that wasn't a dipole, you'd be famous.
M
Magnetic monopoles do not exist.
You realize that iron filings can be magnetized, I hope. And yes, they do clump up in a blob when individual filings are put close to one another.
You can also add these filings to Silly Putty and mix the two up. It makes a cool magnet-hungry blob, as seen in the video at the attached article:
http://science.wonderhowto.com/insp...tty-into-freakish-magnet-hungry-blob-0128239/
QED theory suggests that they should exist. Just because they haven't been found does not prove they do not exist.
I debated on mentioning this, almost any magnetic material will retain a residual magnetic charge when removed from a strong field.
I'm curious what would happen around a DC current flow.
Let me rephrase the question:
Does there exist any kind of liquid-glue that can dry, which after drying has a permanent magnetic field?
IDK what drying has to do with producing a magnetic field. It seems to me if you can put magnetic powder in Silly Putty, you can do the same with a pot of glue.
Yes,
But as much as i understood, the magnetic putty has no self magnetic field, it reacts to the magnetic field of a magnet. i am looking for such a kind of putty or rather drying color, which has a measurable self magnetic field after drying. Not the kind of liquid matter that relies on a magnet to react, but liquid-plastic drying matter which has its own magnetic field.
roineust said:
Yes,
But as much as i understood, the magnetic putty has no self magnetic field, it reacts to the magnetic field of a magnet. i am looking for such kind of putty or rather drying color, which has a measurable self magnetic field after drying. Not the kind of liquid matter that relies on a magnet to react, but matter which has its own magnetic field.
I'm not sure what you are trying to say here.
The Silly Putty in the video demonstration was magnetic due to the powder mixed in it. A bunch of tiny little magnets can create a magnetic field, just not with the same field strength distribution as a big bar magnet can, for example.
If i take a ferromagnetic powder, such as in the following link and a Hall effect sensor and spread a few grams of the powder, as in drawing with sand on the table, will the Hall effect sensor be able to detect the powder lines?
If the answer is NO, does there exist such a powder or such a plastic-liquid, that does have such properties?
If the answer is YES, is it still yes, if i mix the powder at a certain ratio, with some sort of plastic-liquid?
http://www.ebay.com/itm/261141008974?_trksid=p2060778.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Beats me. Why don't you get some magnetite powder and do an experiment?
  • · Replies 42 ·
14K
  • · Replies 16 ·
