Can Hitting Metal Make it Magnetic?
  • Context: High School
  • Thread starter Thread starter Th3Proj3ct
    Magnetism Metal
Hitting a screwdriver with a hammer can induce magnetism in the tool due to the alignment of its magnetic domains. This process, often referred to as work hardening or plastic deformation, allows the screwdriver to temporarily attract ferromagnetic materials like nails or screws. The effect is weak and requires the screwdriver to be aligned with magnetic north for optimal results. The vibrations from the impact help the magnetic domains respond to the Earth's magnetic field, causing them to realign.
  • Understanding of magnetic domains
  • Familiarity with work hardening and plastic deformation
  • Basic knowledge of ferromagnetism
  • Awareness of Earth's magnetic field
  • Research "magnetic domain alignment techniques"
  • Explore "work hardening effects on metal properties"
  • Study "plastic deformation in ferromagnetic materials"
  • Investigate "Earth's magnetic field and its influence on magnetism"
This discussion is beneficial for materials scientists, physics students, and anyone interested in the principles of magnetism and metalworking techniques.
Th3Proj3ct
If you take a screwdriver for example, and hit it a few times near the tip with a hammer or something hard; why does the screwdriver become magnetic?
I was shown someone doing this, and shortly afterwards it was able to attract nails or screws around.
I've never seen this. Maybe the head of the hammer was magnetized. If anything, hitting a magnetized object generally weakens it magnetization.
Actually, we used to do it once in a while just for fun. The metal rod or whatever has to be aligned with magnetic north. It seems that the vibrations loosen up the magnetic domains enough that they react to the Earth's field and turn around. The effect is very weak, though.
Ahh, interesting. Thanks for that Danger! I would have never thought of that. Learn something new every dang day here on the PF!
Wow... I never thought that I'd get one over on you, especially in this area. :bugeye:
:smile: Pppffffttttt! They don't call you Danger for nothing! :biggrin:
Searches using "work hardening", "plastic deformation" and magnetization did yield a large number of articles, for example:
http://ieeexplore.ieee.org/iel5/20/19613/00908685.pdf?arnumber=908685
But I could locate a clear discussion of the subject.
  • · Replies 22 ·
  • · Replies 42 ·
  • · Replies 18 ·
9K
  • · Replies 31 ·
