Magnetism Question: Charged Oil Drop in Electric Field
  • Thread starter Thread starter Dberry
    Magnetism
The discussion revolves around a charged oil drop falling through an electric field created by two plates, with participants exploring the implications of the charge on the oil drop and the necessary magnetic field direction to maintain a straight trajectory.
  • Participants are questioning the charge of the oil drop and how it relates to the electric field's influence on its motion. Some are exploring the consequences of assuming the drop has a negative charge and how that would affect the required magnetic field direction.
There is an ongoing exploration of the relationship between the electric field and the charge of the oil drop. Some participants have provided insights based on the book's explanation, while others are seeking clarification on assumptions regarding the charge of the drop and its implications for the magnetic field direction.
Participants note the lack of explicit information regarding the charge of the oil drop in the problem statement, leading to uncertainty in their reasoning. There is also mention of a potential error in the question based on the provided information.
Dberry
A charged oil drop is allowed to fall through the electric field created by the plates as shown:
l l
l l
l l
In order to give the oil drop a straight trajectory, a magnetic field should be established with field lines pointing:
A. to the right
B. to the left
C. out of the page
D. into the page
The back of my book says that "the electric field between the plates will push a positive charge to the right, so the magnetic field must push the drop to the left to counter the force."
What I don't understand is how am I to know if the oil drop has a positive or negative charge since it is not stated in the question?
You are given the charge on the plates so you should be able to know the charge on the drop from the way it is pushed... look carefully
l l
l l
l l
A. to the right
B. to the left
C. out of the page
D. into the page
Expanding on the solution given in the book... What happens if the oil drop had a negative charge?
(I don't have any figure.)
The book shows the drop falling directly in between the plates and doesn't show it being pushed in any direction.
If the drop were negative I assume it would move to the right towards the positive plate (since opposites attract).
What I don't understand is how am I to know the charge on the oil droplet?
In your diagram it looks, to me, as though the left plate is + and the right plate is -.
If the drop is falling between them and is moving to the right then this tells you the charge on the drop.
You can only know this from what it says in the back of the book !
That's what I think too! It must be an error in the question because the drop is not shown to have any positive or negative orientation. I just wanted to know if it was a book error or if there was something I didn't understand.
Thanks everyone for all your help! :)
I'll ask again.
What will happen if the charge on the oil drop is negative?
In what direction will the plates tend to push the charge?
In what direction will the magnetic field need to point to keep the oil drop centered?
