How does the magnetization of an atom change at its center?
The discussion centers on the magnetization of an atom at its center, specifically using the formula J(r)=(r^3-R^3)/(2R^3)*I/(2*pi*r). Participants debate the validity of applying this formula at r=0, with one contributor suggesting that the magnetization approaches negative infinity, which is deemed incorrect. There is a call for clarification on the range of r for which the formula is applicable and how to modify it for r
Lord33
We have coaxial cabel with radius R and R0=3R filled with magnetic.Magnetization J(r)=(r3-R3)/(2R3)*I/(2*pi*r).What is the magnitization if r=0(center of atom)?And what a magnetization direction of atom?
I think what magnitization in center of atom = -inf , but it is wrong.
The formula for the magnetization works in a limited range (for r) only. Can you find that range?
You can modify the formula a bit to make it applicable at r=0.
I understand what we must take radius of atom but how i can modified a formula if r<ra?I find limit and get -inf it is wrong.I know that J=∑P/ΔV.
You don't need the radius of an atom.
Your formula has an I in it. What is that? A current, sure, but a current of what? Every cable in the universe? Which current exactly do you have to consider in that formula, and is it the same current for every place?
  • · Replies 20 ·
