Magnitude and direction of acceleration
The discussion focuses on calculating the magnitude and direction of acceleration while sliding towards home plate after reaching a speed of 5.9 m/s. The calculated acceleration is 5.36 m/s², but clarification is needed on its direction, which could be toward home plate or third base. To determine the distance slid, participants discuss using the equation d = vt + 1/2at², acknowledging the need to consider the final velocity as zero. Alternative methods, such as using the relationship V² = 2ax, are also suggested for calculating distance. Understanding the relationships between distance, time, and acceleration is emphasized as crucial for solving the problem effectively.
bumblebee
1. You are going toward home plate at speed of 5.9 m/s when you hit the dirt. You slide for 1.1 s just reaching the plate as you stop.
a)What is the magnitude and direction of your acceleration?
b) How far did you slide?
I got 5.36 m/s^2 for the acceleration. Not sure if I did this right.
Welcome to PF.
That looks OK for magnitude. Which direction was the acceleration? Toward the plate or toward 3rd base?
Now how far was the slide. Do you have an equation that would give you the distance if you know the acceleration and time?
Thanks, LowlyPion.
Is it d=vt + 1/2at^2?
I'm getting all these equations confused.
bumblebee said:
Thanks, LowlyPion.
That works as long as you realize that you are coming to a stop, so velocity will be 0.
Alternatively since you also know velocity you could use the relationship that
V2 = 2 a x
That should yield the same result.
It's important to understand that the relationships between distance, time, acceleration can be reworked in a number of ways to express things in terms that you may have directly to find what you need.
This link may provide you with a list of the equations as a brief reference:
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
Thanks! This helps!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
