Magnitude of acceleration with friction
The problem involves calculating the magnitude of acceleration of a block being pushed across a horizontal surface with a force of 20 N at an angle of 30 degrees. The coefficient of kinetic friction is 0.30, and the mass of the block is 3.0 kg. The correct approach requires recalculating the normal force by adding the vertical component of the applied force (20 N * sin 30) to the gravitational force (mg). This results in a normal force of 11.82 N, leading to a final acceleration of 1.8 m/s² after correctly applying the frictional force.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of frictional force calculations (Fk = μ * N)
  • Ability to resolve forces into components (horizontal and vertical)
  • Familiarity with trigonometric functions (sine and cosine)
  • Study the derivation of normal force in inclined scenarios
  • Learn about the effects of angle on frictional force
  • Explore advanced applications of Newton's laws in dynamics
  • Investigate the impact of different coefficients of friction on acceleration
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the dynamics of motion with friction.
bolivartech
A block is pushed across a horizontal surface by the force shown (The force is from the left at an angle 30 degrees above the horizontal). If the coefficient of kinetic friction between the block and the surface is 0.30, F=20 N, theta=30 degrees, and M=3.0kg, what is the magnitude of the acceleration of the block.
Fk=(.3)mg
F-Fk=ma
(20 N)(cos 30) - (.3)(3.0 kg)(9.8 m/s2) = (3.0 kg)a
a = 2.83 m/s2
This is incorrect though, and some how should be 1.8. I have tried separating it into X and Y forces and taking the magnitude (square root of x2+y2, but that is even farther away)
Vertical component of the applied force contributes to the normal reaction. So you to recalculate the frictional force.
Alright I've thrown this in a few varying ways, but let me just say what I'm thinking so you can let me know where I've gone wrong. The frictional force is the coefficient * mass * gravity, and the Normal is mass*gravity. Since the force has a vertical element then it is also contributing to the downward force, 20N*sin30. Do I just add the result of that downward force to the frictional force?
No. downward force 20Nsin30 adds to mg. These two constitute the normal reaction. From that find the frictional force.
I've never seen it that way before but I think I'm starting to get it. In my free form diagram I drew the NL as mg + Fsin30. So Fk is not Ukmg, but UkNL. Which comes out to 11.82 in this scenario, and put in exactly as I had it setup before makes the acceleration 1.8. Thanks so much, not only did I get the right answer, I understand why!
  • · Replies 19 ·
  • · Replies 23 ·
